Camber Plates?
Old Nov 19, 2001 | 06:22 PM
fatmike's Avatar
Camber Plates?
first does anyone other than stillen? second how much is stillen charging for theirs? I have kyb struts and ground comtrol coilovers in the mail and i figured camber plates would be neccessary
Old Nov 19, 2001 | 08:55 PM
Nismo's Avatar
Re: Camber Plates?
eibach has a camber kit for like $30 I think
Old Nov 20, 2001 | 07:05 AM
1MAX2NV's Avatar
Re: Re: Camber Plates?
Ebiach won't help if he's planning on dropping more than 2". Any camber plates it's going to be expensive. I believe GC sells some too. I believe they are in $200 range.
Old Nov 20, 2001 | 07:49 AM
njmaxseltd's Avatar
Camber BOLTS
There are no such things as camber plates for our cars. There camber bolts and the cost is around 30 bucks for a kit. They come in two sizes, one to adjust up to about 1 degree and another bolt that will adjust up to around 2 degrees.
Old Nov 20, 2001 | 08:39 AM
1MAX2NV's Avatar
Re: Camber BOLTS
Really!!! What are these on my car?
Old Nov 20, 2001 | 09:37 AM
AdMax98's Avatar
No way man, they dont make them for our cars! Thats photoshopped!
heh jk
Old Nov 20, 2001 | 09:51 AM
theblue's Avatar
while on the subjext I want some more opinions. I'm installing GC + AGX and I want to know if I really need camber plates (or anything else) i don't plan on dropping anything lower that 2" except for a few rare cases when I want to show my car or do it just for a day for fun
Old Nov 20, 2001 | 09:58 AM
1MAX2NV's Avatar
If you don't plan on driving around with more than 2" drop, you won't need camber plates. The only reason I have them, because I got them used.
Old Nov 20, 2001 | 10:14 AM
theblue's Avatar
excelent... thanks for confirming my thoughts. what will happen (apart from excessive tire ware) if I do decide to drop them 2.25? I was thinking of slamming it when I autoX
Old Nov 20, 2001 | 10:41 AM
njmaxseltd's Avatar
Re: Re: Camber BOLTS
Those plates look nice! Never saw that setup before. The bolts do the same thing and I'm sure cost a lot less and are easier to install.
Old Nov 20, 2001 | 10:45 AM
1MAX2NV's Avatar
Just inner tire wear. If you do autox, you probably want the excessive negative camber anyway
Old Nov 20, 2001 | 10:50 AM
matt calder's Avatar
I have mine dropped more than 2 inches and dont have any excessive tire wear either. I guess I got lucky or something
Old Nov 20, 2001 | 12:13 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: Re: Camber BOLTS
The bolts only give you about 1 degree of adjustment, the plates give you almost 4.
Old Nov 21, 2001 | 07:57 PM
SLC I30t's Avatar
Re: Camber BOLTS
Hmm I guess you've never seen a stillen cataloge before huh?
I also believe that the plates mount on the same studs as the FSTB(front tower strut brace---yes they make these) I cant believe it would be difficult to put those on when changing out your suspension.
Old Nov 22, 2001 | 06:51 AM
fatmike's Avatar
Ground Control?
does ground contol make plates also where are these "bolts" sold and who makes them... I have heard of a lot of people dropping 2'' and no probs..if I dropped mine 2.5'' dont you think I could get away with just bolts?? Please help I dont want to end up paying a months salary just to go through stillen
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
