question about fpr?
Old Apr 5, 2009 | 08:30 PM
Kico's Avatar
question about fpr?
I have a jdm fuel pressure regulator and the gauge stop working, so i got a new one and it doesn't work. I checked and even had my mechanic checked and it is hooked up correctly. I think that it could be the rubber diaphragm inside the fpr. But i think it is still working but i am not sure, haven't noticed a diff. in the way the car was running since i first put it on. But while i was adjusting it while the car was running if i turned the screw to far in on the fpr the car would start to die. So i backed it out while squeezing the fuel line to feel the pressure as i would relive the pressure by turning the screw out of the fpr. So i don't know where i have it adjusted but the car seems to be running fine. But gauge doesn't work. If anyone can let me know if there is a rebuild kit for them or am i just stuck buying a new one?
Old Apr 5, 2009 | 08:57 PM
pmohr's Avatar
No more Maximas...
An actual 'JDM' FPR from a VQ, or some sort of aftermarket FPR?
Rebuild kit for the gauge? Unlikely.
Just get a new one, they're relatively cheap.
Old Apr 5, 2009 | 09:00 PM
Kico's Avatar
it is a aftermarket one, I already got a new gauge i was talking about a rebuild kit for the aftermarket fpr. Probably not likely! I'm probably stuck buying a new fpr.
Old Apr 5, 2009 | 09:02 PM
pmohr's Avatar
No more Maximas...
Exactly what type of FPR? Without knowing the brand/model, there's really no way to know whether or not there's a rebuild kit available.
Generally speaking, most of the good ones do have kits available.
Old Apr 5, 2009 | 09:03 PM
Kico's Avatar
I bought it off ebay and it said that it was jdm fpr
Old Apr 5, 2009 | 09:08 PM
pmohr's Avatar
No more Maximas...
No manufacturer name stamped on the FPR itself? Do you have a link to an eBay auction for the same?
Old Apr 5, 2009 | 09:12 PM
Kico's Avatar
It says its jdm in the description....
http://cgi.ebay.com/ebaymotors/ws/eB...3A11&viewitem=
Old Apr 5, 2009 | 09:15 PM
Kico's Avatar
I have the correct adapter for it also!!
Old Apr 5, 2009 | 09:17 PM
pmohr's Avatar
No more Maximas...
Again, no manufacturer name on the FPR itself?
It's cheap enough to buy another one, rather than spending a week looking for a rebuild kit.
Why do you need an FPR, anyway? Are you trying to adjust ignition timing with an SAFC, have any real mods? Any actual need for a different fuel pressure?
Looking through your post history, there's no real indication of any modifications.
Old Apr 5, 2009 | 09:21 PM
Kico's Avatar
I have a obx header back exhaust, cold air intake, and throttle body spacer. I was going to buy a new one to replace it and why not replace it with a after market one and i am also going to be putting in a walbro fuel pump.
Old Apr 5, 2009 | 09:25 PM
pmohr's Avatar
No more Maximas...
Well you don't really need the aftermarket FPR, especially not at your mod level (nor the Walbro), but okay then.
Easiest (if you want to keep this route) is just to buy another one.
Kico's Avatar
figured as much but thanks!!
Old Apr 5, 2009 | 09:28 PM
MaxGordon7's Avatar
People when it says jdm most of the time it is a sale pitch. Like what auto store employee do to everything on sale :P
Old Apr 6, 2009 | 02:20 PM
RA030726's Avatar
I'm nutty for Nissans
if you need another i have one like in the auction but all chrome . ive never used it and id sell it real cheap.
http://cgi.ebay.com/ebaymotors/FUEL-...QQcmdZViewItem
its probably missing some things from the kit but the gauge and regulator are there
Old Apr 6, 2009 | 02:38 PM
Kico's Avatar
how much would you want for it??
Old Apr 6, 2009 | 04:53 PM
Flava_24/7's Avatar
Boosted Panda
Why do you need an adjustable FPR?
What was wrong with the stock one? Why do you need a Walbro fuel pump?
Seems like your just creating problems for yourself.
Old Apr 6, 2009 | 04:57 PM
Kico's Avatar
Its for future mods...
Old Apr 6, 2009 | 05:09 PM
Flava_24/7's Avatar
Boosted Panda
So your going to boost?
IMO, you should just wait. There are other mods you could do that with that money that would actually give you gains.
All your going to be doing is creating an issue, and then installing another part to solve it, waste of money really since no gains are being made from installing those parts. Im boosted and dont run an AFPR, a Walbro however is needed.
Old Apr 6, 2009 | 05:23 PM
Kico's Avatar
like what other mods are you suggesting...
Old Apr 6, 2009 | 05:31 PM
Flava_24/7's Avatar
Boosted Panda
Y pipe or equal legnth headers, A VI, ECU upgrade, etc.
H#ll, even a BBK setup would be more benificial.
Old Apr 6, 2009 | 05:41 PM
Kico's Avatar
I have a stainless steal obx racing header back exhaust...but what does bbk set up mean?
Old Apr 6, 2009 | 05:43 PM
pmohr's Avatar
No more Maximas...
Heh, 'racing'.
BBK - Big Brake Kit.
Old Apr 6, 2009 | 05:50 PM
What future mods are you talking about that will actually benefit from an AFPR??
Old Apr 6, 2009 | 05:57 PM
Flava_24/7's Avatar
Boosted Panda
Is it the newly designed OBX headers or the older ones?
Catback exhaust wont do much for performance anyways.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
