95max bought new in 95 still original Spark plugs
Old Apr 6, 2009 | 01:45 AM
flynlr's Avatar
so I have had this beast for just under 14 years now, all the standard maintenance done, but since I have yet to hit 100K }{now at 65K}
I never got around to changing the plugs. It seems my gas Mileage, is now set on 22MPG now matter how I drive so I was
1. wondering if i have stripped threads in my future,
2.if changing the plugs would help at all,
I have no codes in the computer at this time and car is running great. .
Old Apr 6, 2009 | 02:29 AM
Jessiblack's Avatar
I bought a 95 Maxima w/155K miles that had been sitting for quite a while. I
have been getting it shape (1/2 shafts, spark plugs, oil change, brakes and
rotors, new #4 injector and temp sensor and bank 2 #1 O2 sensor). ... I still
have a slightly rough idle and minor missing but no chk eng light
Old Apr 6, 2009 | 05:42 AM
Bassbreaker's Avatar
14 years old and only 65K?!?! Wow man. I have 270K on mine..lol...
You should have no problem takein out those plugs.
Old Apr 6, 2009 | 12:37 PM
ptatohed's Avatar
Licensed to Spell
Yes, change your plugs.
Old Apr 6, 2009 | 12:43 PM
maxfever1987's Avatar
chage ur plugs, not much miles on them but 14 years is old for spark plugs, you should feel some type of change your car u put new ones in, STAY AWAY FROM BOSCH, USE NGK's
Old Apr 6, 2009 | 05:50 PM
Product_Of_Korea's Avatar
Best advice ever.
Old Apr 6, 2009 | 06:04 PM
i want to see pics of that car!!!! what are you like a little old lady or something????
lol
Old Apr 6, 2009 | 06:28 PM
AEMAXIMA01's Avatar
me too!
Old Apr 6, 2009 | 06:38 PM
Definitely change those plugs. Get some NGK Coppers. Cheap and exactly what you need.
Old Apr 6, 2009 | 06:53 PM
rf97's Avatar
Definitely change the plugs, and like everyone else says, go with NGK. I had installed Bosch in my car and the car didn't feel right, change them out to NGK Copper and my baby is running nice and strong again.
Old Apr 6, 2009 | 06:55 PM
vqmaxman's Avatar
I would change the following on the car:
PLUGS,FUELFILTER,AIRFILTER,BRAKE FLUID,PCV VALVE.
BRAKES (If they are needed) HOSES(cracked or caked on or leaking)
SHOCKS(If they are bad and are leaking)
STRUT MOUNTS (if there making noise)
AXLE (If the CV boot Is torn)
BALLJOINTS (If there leaking grease or they are rusted)
ROTORS (If there rusted or there under specific reg)
Old Apr 7, 2009 | 12:56 AM
flynlr's Avatar
PLUGS,FUELFILTER,AIRFILTER,BRAKE FLUID,PCV VALVE. Done -Plugs
BRAKES (If they are needed) HOSES(cracked or caked on or leaking) Done
SHOCKS(If they are bad and are leaking) still factory
STRUT MOUNTS (if there making noise) no noise
AXLE (If the CV boot Is torn) changed due to rot 3 years ago
BALLJOINTS (If there leaking grease or they are rusted) never looked at em
ROTORS (If there rusted or there under specific reg) brand new as of last month
NGK it is thanks ...
and for your viewing pleasure a plain old 95 max GXE with 65K on it.
walmart wheel covers and all. btw 20K of those miles are in the last 3 years.
before that I had almost no commute at all.
Old Apr 7, 2009 | 03:52 AM
wow the hood struts still work lol. i cant remeber last time that happed for me
Old Apr 7, 2009 | 04:07 AM
my 95's hood struts still work...but my paint isn't as pristine as that tho...nice car to start a build with man
Old Apr 7, 2009 | 04:08 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Be careful, your tires may be dry rotted from all that sitting around
Old Apr 7, 2009 | 06:09 AM
maxboy325's Avatar
This car is DUMB clean.....
Old Apr 7, 2009 | 08:20 AM
allensteiner21's Avatar
immaculate. i wish my paint was looking half as fresh.
Old Apr 7, 2009 | 10:08 AM
ThreePointO's Avatar
just fixed mine. =]
Old Apr 7, 2009 | 10:14 AM
maxima.713's Avatar
MINT! any intirior pics??
Old Apr 7, 2009 | 01:13 PM
COliveira's Avatar
That is a super clean and low mileage 95. Great job keeping it that way. As suggested above, I would definitely do a 60k service on it (plugs, PCV, air filter, fuel filter, belts, etc.) Depending on what other maintenance you have done I would check out all the fluids, etc. That's just me.
Maybe you should pull the codes and see if you have P0325 Knock Sensor code. That MAY be a contributing factor to your fuel mileage which doesn't trigger the check engine light. Good luck with the car and again, props for keeping it really clean!
Old Apr 7, 2009 | 01:19 PM
flynlr's Avatar
just went outside and took a couple. I was off on the mileage a bit.
hood struts changed a few winters ago after cranial contact,
Old Apr 7, 2009 | 02:06 PM
ZaxWhite97Max's Avatar
Lol! What! I don't even have hood struts anymore I cut those off lol!
Your can see reflections in your bumper. I can't in mine lol!
Nice job keeping it so clean, I want to see underbelly shots.
Where are you from?
I think buy some stock SE rims and clear corners and give her a present.
Old Apr 7, 2009 | 02:25 PM
shook187's Avatar
I would love a 4th with that much miles. I would feel better about modding a car with 60k miles then my Max that has 120k
Old Apr 7, 2009 | 03:03 PM
im modding my car @ 185k
Old Apr 7, 2009 | 05:20 PM
vqmaxman's Avatar
WOW.... the car looks very nice and clean, It looks new and It can pass
for a 97-99 thats in good condition. I will have to be honesty, this is one of
the
cleaniest 95 maxima's I've seen in a while.
Old Apr 7, 2009 | 05:32 PM
fcoral 05's Avatar
car looks totally good i saw a 95 max with on 32xxxk on it about 2 months ago and in mint condition i tried to get the owner to trade it in so i can buy it but he did not budge he said he loves it and will not get rid of it he was with his friend and they purchased an 09 caddy sts. So they still got low milage maximas out there.
Old Apr 8, 2009 | 01:45 AM
shook187's Avatar
http://cgi.ebay.com/ebaymotors/95-MA...1%7C240%3A1318
Old Apr 8, 2009 | 04:17 AM
^ Tousche! My '96 with 220K.
Old Apr 8, 2009 | 05:26 AM
shook187's Avatar
This thread has taken a turn.
Old Apr 8, 2009 | 05:31 AM
Like most threads do. They usually become OT, then get locked. His answer was answered already so its all good.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
nbstriker10
Sep 4, 2015 04:26 PM
Johnny9595
Sep 3, 2015 05:18 AM
