vacuum hose reattachment
Old Apr 10, 2009 | 06:12 PM
Maximeltman's Avatar
is there some illustrative information on where the vacuum hoses are attached where the intake is? There is a shiny little tube on the intake plastic part that a vacuum hose attaches to, and there's another small shiny tube facing down on the intake as well where another vacuum hose attaches...I have one vacuum hose that has a dounle insulation like to protect iot from heat where does that go? I know I should have marked them before I took them off.
Old Apr 10, 2009 | 06:16 PM
IlyaK's Avatar
The Golden One
Look at the underside of your hood near the driver side. You'll see a diagram. That diagram saved my *** when I was re-doing my vac. lines.
Old Apr 10, 2009 | 08:00 PM
pmohr's Avatar
No more Maximas...
Aftermarket intake? That's what it sounds like.
What brand intake?
Have a pic?
Old Apr 10, 2009 | 08:20 PM
IlyaK-thanks I'll check that out!!
Pmohr-stock maxima intake...I forget what the thing with the metal flap inside is called oh yea the throttle body!!
There's a small little metal tube that points directly down under the TB and I think that a vacuum hose connects to it. And on the other big plastic accordian next to the MAF there's another small shiny metal tube that a vac.hose connects to...Right now there's an unconnected vac hose with that double rubber insulating slip over it that I mentioned earlier...like a protector from heat...
Old Apr 10, 2009 | 08:28 PM
IlyaK's Avatar
The Golden One
Most of the lines going to the TB are coolant lines...
Old Apr 10, 2009 | 08:39 PM
pmohr's Avatar
No more Maximas...
The vacuum line directly beneath the TB goes to the vacuum gallery, IIRC the one that makes it's way to the FPR.
The one on the resonator goes to the EVAP canister, at least it did on my car. This is where the insulated line goes, I believe.
What year/emissions spec are you?
Old Apr 10, 2009 | 09:33 PM
99 fed. Pmohr, when you say vacuum gallery, are you referring to the mass of tangled steel tubes that join the hoses underneath the TB?
Old Apr 11, 2009 | 10:46 AM
pmohr's Avatar
No more Maximas...
Indeed.
Old Apr 11, 2009 | 05:19 PM
ya thats how I have them, thanks!
Old Apr 13, 2009 | 12:02 AM
killerVQ30DE's Avatar
I snapped this hose as it was on so tight when I was removing the tb.. there was enough slack to put it back on luckly.
Is this a critical line? I'll have to try Nissan I think because of the whole double insulated
Old Apr 13, 2009 | 07:09 AM
IlyaK's Avatar
The Golden One
I used Napa/Auto Store hoses, no problems.
Old May 7, 2011 | 11:01 AM
1kennyb's Avatar
does anyone know where to find a free printable vacuum diagram for a 95 max?
Miket2006
Mar 1, 2021 03:55 AM
conansriver
Nov 18, 2015 02:46 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
MaxDD
Sep 24, 2015 06:40 AM
followthadollar
Sep 13, 2015 09:55 AM
