P0600
Old Apr 16, 2009 | 09:56 PM
mahanddeem's Avatar
P0600
Hi
If this code is related to A/T tranny (MAX 97).......I'm thinking , what are the electrical or electronical connection in and out the A/T ??? because mechanically my A/T is going fine without problems !
Thanks.......
Old Apr 17, 2009 | 11:12 AM
pmohr's Avatar
No more Maximas...
The code is specifically for the harness or the TCM. Have you worked either in the center dash or under the hood recently?
And weren't you asking about this same code in your other thread?
http://forums.maxima.org/4th-generat...ese-codes.html
Old Apr 17, 2009 | 02:10 PM
mahanddeem's Avatar
Sorry master.........Some friend only changed the instrument cluster for me (some thing is...When I turn the key from off to on (to start the car)the trip odometer like it turn 1/4 or 1/5 of the feet meter in the trip odo !!!)..Another note:the small lamp for the seat belt in the back of the cluster is missing (seemsa like the previous user didn't want to put seat belt ! may contribute to P0600 code !? other under the hood , they flushed the AT for me couple of days ago !
Sorry man...I'm kinda very beginner for car service.. Your expert help is much appreciated ...Sorry for my messing things !!!
Old Jun 11, 2009 | 08:55 AM
Maxien's Avatar
I have a 97 max A/T And I am getting this code along with p0500 I replaced both transmission speed sensors and the tcm. Still keeps coming back any suggestions?
Old Jun 11, 2009 | 11:07 AM
G4nismo's Avatar
has anyone altered w/ the ECM/TCM harness? could have a short in one of those wires thus transferring incorrect voltage.
check and see if the harness connectors are plugged in all the way. then try resetting the ecu to see if the code goes away.
Old Jun 11, 2009 | 03:21 PM
JtzMax's Avatar
Whatchyou say?
Yea ... for one, read and follow the rules of the forums! http://forums.maxima.org/4th-generat...e-posting.html
If you have replaced the TCM, it's likely the harness that is bad or has a bad spot.
Old Mar 19, 2014 | 06:14 PM
WvaHellbilly's Avatar
Question about OBD II codes P0600 and P0500 and speedometer.
Hi everyone. I recently purchased a '97 Maxima SE, so I am new to the Nissan world and to the forum. I didn't realize Maxima's had such a great following. I am glad I found this forum!
I have looked through the forum about the codes P0600 and P0500. Plus, My speedometer stops working every now and then. From what I have read, I think that I need to start by taking a look at the cluster and do some repairs. I think that the speedometer is causing both error codes. Any information on how to check and narrow down the problem or possible fixes would be greatly appreciated.
Old Mar 19, 2014 | 10:31 PM
DennisMik's Avatar
See my answer in your other post on this that you made in the "I am new here and have a question" thread.
And please don't be making multiple posts for the same problem. We don't like that.
artinfinitii30
Dec 1, 2014 12:34 AM
darkdream
May 14, 2014 08:40 PM
TRANK23
Jul 8, 2012 08:03 PM
mrmagicpapi
Jun 29, 2011 02:42 PM
