Need help with some codes
Old Apr 27, 2009 | 07:49 PM
sicivic89's Avatar
The service engine soon light has been on for the past week. I checked the codes today and got TPS(4 long - 3 short), EGRC Solenoid valve(10 long - 5 short), and front left heated O2 sensor (3 long - 3 short). The check engine light came on during a long road trip. I have had the TPS code pop up before on long road trips, but not the other two codes. Any ideas? Could the codes be related?
The car drives fine for the most part. If I am cruising as a constant speed and then slowly lay into the gas, its not a smooth transition sometimes. I really have replaced the spark plugs.
Old Apr 28, 2009 | 06:08 AM
pmohr's Avatar
No more Maximas...
FWIW it's best if you post the codes, not the descriptions (or both).
Well...what do you mean any ideas?
Have you not yet tested any of the components that set a code? Checked the harness connectors, nothing?
Seems like the first logical step to me.
Old Apr 28, 2009 | 06:20 AM
sicivic89's Avatar
I added the number of blinks next to each code above. My point in asking was to see if the codes are possibly related.
Old Apr 28, 2009 | 06:33 AM
pmohr's Avatar
No more Maximas...
It's possible, if it's a harness issue. That's why you need to give the area (at the very least) a visual check...
Old Apr 28, 2009 | 06:41 AM
sicivic89's Avatar
Alrite, I'll check the harness later on today. Should I check it at each of those sensors? Or another particular place?
Old Apr 28, 2009 | 06:53 AM
pmohr's Avatar
No more Maximas...
Visual check of all the sensors that set codes, check the connectors on each of them for corrosion, reseat the connectors. Then reset the codes, see which come back.
Old Apr 28, 2009 | 06:13 PM
enik24's Avatar
dont worry about the o2 sensor code mine came on both when i had to clean the egr and when i had to get a new knock sensoer.
Old Apr 29, 2009 | 08:44 PM
96_vqmax's Avatar
my wife 95 has the same p1005 and p0503,anyone know the code(p1005) is the egr valve itself or other part of the egr system and where it is locate at?thank.
ps.sorry sicivic89 didn't mean to hijack ur tread or something,just don't want to start a thread with the same problem.btw did u get ur problem fix?thnx..
Old Apr 29, 2009 | 08:45 PM
pmohr's Avatar
No more Maximas...
Your wife doesn't have P1005, because there is no P1005 DTC.
Old Apr 30, 2009 | 08:08 AM
sicivic89's Avatar
I haven't fixed it yet. Still need to check the harness and such. I going to reset the codes and see which ones come back.
Old May 1, 2009 | 12:58 AM
96_vqmax's Avatar
well when i pull the code it flash 10 longs and 5 shorts pulse,is that 1005 no?
Old May 1, 2009 | 08:06 AM
nafddur's Avatar
Looks to me like you're mixing up the MIL and consult codes. As pmohr pointed out, there is no p1005 DTC. But (from page EC-65 in my 95 FSM)there IS a 105 MIL code for the EGRC Solenoid valve.
And (FWIW) a 32 MIL DTC - a general EGR code -that drove me crazy for a long time turned out to be only the EGR and canister control SV. A $94 part from the dealer that took about 15 minutes to change.
Old May 1, 2009 | 09:05 AM
sicivic89's Avatar
10 longs and 5 shorts doesn't mean 1005. You need to go to the stickie at the top of the 4th Gen forum and there will be a thread with a link where you input the long flashes and the short flashes and it will give you the issue.
Old May 1, 2009 | 09:41 AM
96_vqmax's Avatar
sorry for the confusion pmohr,thank nafddur,so where is this sv locate at,cause the 95 and 96 are different,thank for all the help guy,i lost my service manuel that why i can't check it out,if you guys can post some pics of the sv that will be great,don't want to get the wrong part that all,thnx.
Old May 1, 2009 | 10:13 AM
pmohr's Avatar
No more Maximas...
1005, yes. P1005? No.
To keep things less confusing you should really always pad the code out to 4 digits. For example, a KS code isn't 34, it's 0304. Some codes can be tricky like that, for example 105 is 1005.
Well, it does mean 1005. but not P1005.
And you can download the FSM for free, see my sig. Also if you're wondering what a code means, also see my sig.
For example, 1005 for a '95:
Code: P1400 | Description: EGRC Solenoid/Valve
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
