rpm not working on vq30dek
Old May 3, 2009 | 05:45 AM
carlostelevida's Avatar
i ve swaped a vq30de with a vq30dek, but now the RPM didnt work, any help on how to solve this. ?
post: thanks pmohr and locknuts for his help on solve my no spark issue.
Old May 3, 2009 | 07:07 AM
pmohr's Avatar
No more Maximas...
It didn't work or it doesn't work?
You did make sure that all of the engine harness-dash plugs were connected properly, correct?
Check the CKPS POS and CKPS REF.
Old May 3, 2009 | 07:20 AM
it didn't work, but every thing is working except this.
the IACV valve was bad so i swap with the one old, make the proper changes and every thing is like a charm,
for make the iacv swap i follow some of the tuts here in the site.
Old May 3, 2009 | 08:05 AM
Product_Of_Korea's Avatar
make sure there is continuity from the ecu pin#5 to the pin #17 in the back of the speedometer.
Although it seems like if there where wiring issues its probley from the crankshaft sensors like pmhor stated
Old May 3, 2009 | 08:16 AM
pmohr's Avatar
No more Maximas...
What do you mean you swapped with the 'old' one? If you're using the USIM, there's only one IACV you can really use. Did you swap in a DE-K, or was it just a DE?
You had the hacked up engine control harness, right? Seriously, just buy a new engine harness. You've already proved once that the wiring can not be trusted.
Anyway, have you not checked for a tach signal at the ECU?
And you never answered about the engine harness-dash harness connections.
Old May 3, 2009 | 08:44 AM
its a dek, completely
yes, the wiring cannot be trusted like you stated, but here in dominican republic the Nissan dealer doesn't sell parts for this vehicle due to the year of fabrication.
no, it's was working before the swap
it wasnt touched at all when the hacked was maked to the engine.
Old May 3, 2009 | 08:46 AM
pmohr's Avatar
No more Maximas...
no,
If it's a DEK, then how...nevermind, it's not even worth trying to understand.
You wouldn't buy it from the dealer anyway, they'd charge a good $1500+.
If you haven't checked...then check, seriously.
So you did not remove the engine harness from the car to splice the two ends together? If you did, then you unplugged the engine-dash harness connectors.
Old May 3, 2009 | 09:03 AM
i just cut the old wires who were go to replace and solder the new ones,, no plug unplug necessary, didn't touched the ecu even, it was all made near the engine, i didn't touched interior wiring at all.
so did the speedometer have a fuse ?
Old May 3, 2009 | 09:06 AM
pmohr's Avatar
No more Maximas...
Yes, but it affects the entire gauge cluster.
So, have you checked for an RPM reading at the ECU yet?
If not, do so.
Old May 3, 2009 | 09:15 AM
i think there's confusion here, the clock that shows the revolution when you push the accelerator is the RPM right,? that's the one that's not working on my car,
the other, the one that show the speed of the car, i think speedometer, its working right.
pmohr says:
i don't know how to do that.
Old May 3, 2009 | 09:25 AM
pmohr's Avatar
No more Maximas...
pmohr says:
We never said you had a speedometer issue, you're the one that brought up the speedometer.
Yes, the tach displays RPM.
It's pin 5 on the ECU harness connector, you should see it pulsing up to ~5 volt, IIRC. If you have a scope, or an aftermarket tach, all the better.
Old May 3, 2009 | 09:33 AM
dude you are a human fsm....... it is 5v it took me a while to page though the fsm to figure out that pin 5 goes to pin 17(speedo harness) but i did see that it is 5v going from the tach to the ecu(#5) but i suppose it would be easier to see if there is 5v going to the ecu than seeing if there is continuity from the ecu and the harness
Old May 3, 2009 | 09:40 AM
i agree, this man know everything about maximas.
i'm going the check, and post later, but now after your clarification its nothing about the swap then, just for curiosity, whats the sensor that control this, rpm, just for recheck the wiring before check the continuity.
Old May 3, 2009 | 09:43 AM
Those are the sensors that the rpms go off of
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
kenc15
Aug 5, 2015 08:29 AM
