OK, so... I've been slacking off under the hood.
Old May 5, 2009 | 09:16 PM
tyler5619's Avatar
I am just curious of what all I need to do to be "caught" up. My 97 max has 125k miles on it.
I'm thinking a SeaFoam treatment, new spark plugs...what else? is there an easy way to check for clogs, like in the EGR, TB, IACV...is there anything else that can clog?
BASICALLY, i want to get my car back to "new car" status under the hood. What all is needed?
Old May 5, 2009 | 09:28 PM
nsnrider's Avatar
how many miles?
-oil change w/ filter
-tranny fluid drain and refill
-new belts
-coolant flush
-check battery
-brake fluid flush
-air filter
-seals that leak
-CV boots if worn or torn
-etc thats bad.
Old May 5, 2009 | 10:04 PM
tyler5619's Avatar
Originally Posted by nsnrider
how many miles?
125K.
Nothing seems wrong, I just want to perform some "preventive maintenance"
Old May 5, 2009 | 10:53 PM
anomaly117's Avatar
then do everything nsn told you to do. and apart from that... TAKE CARE OF IT, and shell be just fine
Old May 6, 2009 | 12:32 AM
whitealexander's Avatar
how many miles?
-new belts
-coolant flush
-check battery
-brake fluid flush
-air filter
-seals that leak
-etc thats bad.
yep.. this is what i do for thorough maintenance..
Old May 6, 2009 | 05:19 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
how many miles?
-new belts
-coolant flush
-check battery
-brake fluid flush
-air filter
-seals that leak
-etc thats bad.
Two things I would add to the list is....
-gas filter
-PC valve
Old May 6, 2009 | 10:26 AM
96blackmaxSE's Avatar
boost me.....
Clean TB...
Old May 6, 2009 | 05:58 PM
maxfever1987's Avatar
clean iacv as well...
Old May 6, 2009 | 08:49 PM
TLMNICK's Avatar
MAF cleaning, injector cleaning, and battery terminal service also.
Old May 10, 2009 | 08:30 AM
Fasteddie01's Avatar
Just a thought ... Most members don't agree on Seafoam, many think it's a waste. I haven't done it, but I wouldn't. I'd spend the money on engine degreaser/cleaner, so you could see any leaks, ... just be careful around electrical. [I] did it and it makes a world of diff. * Also, if you drive any highway, you should do the cruise 'always-on' mod ...real simple and will save gas money. One last tip, when you do oil change, buy 1 'cheap' Fram filter and one 'good' one, lke NAPA Gold or OEM. Put the cheap one on first and run a couple weeks ( a few hundred miles) then pull Fram off and put on the good filter. That'll remove a lot of crap from oil system, the fram'll probably be full of crap and bypassing anyway. Just have the Good filter ready to screw on and do a quick swap ... you'll only lose a few ounces of oil. Check level and prob not need to add any.
Old May 10, 2009 | 09:25 AM
tyler5619's Avatar
thanks alot man. i did the seafoam and i can tell a difference. but yeah, i really do need to get some engine degreaser!
i do drive highway, but i don't have a problem with pushing the cruise-on button lol.
i have never thought of swapping filters! that is an excellent idea. i have a wix filter on there right now, but next time i do an oil change (3 months from now lol) i'll do that!
Old May 17, 2009 | 06:56 AM
trooplewis's Avatar
And unless you have ABS, you can probably skip the brake flush.
Old May 17, 2009 | 07:43 AM
JwaxMax99's Avatar
Do the brake fluid too, it takes on moisture. BAD
Old May 17, 2009 | 07:51 AM
mahanddeem's Avatar
If you're car runs fine,don't mess with it ......lol...learn that lesson
rtirbany
Sep 8, 2015 11:46 AM
Stagnet04
Aug 16, 2015 11:15 PM
doobadoo
Aug 15, 2015 06:43 PM
Trin1j23
Aug 12, 2015 08:31 PM
Samedi
Aug 12, 2015 01:54 AM
