Glass lens for stock headlight housings ??
May 26, 2009 | 01:32 PM
Anybody know where we can get just the glass to replace the plastic with the stock headlight housings? I know there is polish and sanding, none of it's working and the lens (plastic) seems to be getting even more foggy the more I work with it. So ... I just want glass lens' to replace the stock plastic. TIA!
Cheers ....
May 26, 2009 | 01:46 PM
Get some real (95/96) lights
May 26, 2009 | 08:57 PM
Unless you can find some 97-99 CE glass headlights (discontinued), you may be out of luck! I know someone was recently selling a pair of retro'd CE glass headlights, and ahhh they were siK! Or like Pmohr said, 95/96 is your second best bet!
May 26, 2009 | 10:45 PM
Try this: http://cgi.ebay.com/ebaymotors/HEADL...1%7C240%3A1318
And this:
GL........
May 27, 2009 | 10:55 AM
something that i believe may work, but have not done any kind of real research on, is using the glass housing 2 piece cefiros on ebay with maxima corner lights.
May 27, 2009 | 12:26 PM
I HAVE A MINT CONDITION SET OF 95/96 HEADLIGHTS.....sorry for the caps..on AutoCad...I'll let em go for $50 for the pair pm me if interested
May 27, 2009 | 01:17 PM
Quote: something that i believe may work, but have not done any kind of real research on, is using the glass housing 2 piece cefiros on ebay with maxima corner lights.
They'll fit about as well as the Cefiro 1 piece lights too. Less of a curved contour on the outer headlight face. I tried seeing how my stock I30 lights fit on my Maxima. Not great.
May 28, 2009 | 06:55 AM
Quote: Anybody know where we can get just the glass to replace the plastic with the stock headlight housings? I know there is polish and sanding, none of it's working and the lens (plastic) seems to be getting even more foggy the more I work with it. So ... I just want glass lens' to replace the stock plastic. TIA!
Cheers ....
You cannot simply swap the lenses. The housings that use the glass lenses are styled after the 95-96 housings and have a flat backing as to where the 97-99 lenses have curved backs to fit the 97-99 housings. Trust me, I tried.
Quote: Unless you can find some 97-99 CE glass headlights (discontinued), you may be out of luck! I know someone was recently selling a pair of retro'd CE glass headlights, and ahhh they were siK! Or like Pmohr said, 95/96 is your second best bet!
The CE glass headlights were the same as the Ebay units, and once again they were styled after the 95-96 headlihgts, just with clear lenses.
Quote: They'll fit about as well as the Cefiro 1 piece lights too. Less of a curved contour on the outer headlight face. I tried seeing how my stock I30 lights fit on my Maxima. Not great.
True, Dubbya purchased some of these when they first came out and the fitment wasnt so great.
May 28, 2009 | 11:45 AM
Well ... since I have retrored my stock housings, I would have to mod the 95 - 96 housings - maybe not worth it. Perhaps I can find some cleaner plastic for the 97 - 99 housings .... just use that. Thank you all for the input, sucks ... but whatchya gonna do?
May 28, 2009 | 02:37 PM
Try some Brasso on those lenses.
May 28, 2009 | 03:13 PM
Im confused. You've got 97-99 headlights, right? And you're looking for 97-99 style glass replacements, right? Why all the "go get some 95/96 headlights" suggestions, because IMO, the 97-00 style looks better and outputs better than the 95-96 style...
May 28, 2009 | 05:12 PM
Quote: Im confused. You've got 97-99 headlights, right? And you're looking for 97-99 style glass replacements, right? Why all the "go get some 95/96 headlights" suggestions, because IMO, the 97-00 style looks better and outputs better than the 95-96 style...
I wasn't aware that headlights from the 2000 Maxima worked in the 4th gen.
May 28, 2009 | 05:17 PM
BECAUSE, the 95-96 replacments have clear glass lenses, no fogging or yellowing.
The headlights on my car in my sig are the clear glass units.
May 28, 2009 | 05:21 PM
Quote: Well ... since I have retrored my stock housings, I would have to mod the 95 - 96 housings - maybe not worth it. Perhaps I can find some cleaner plastic for the 97 - 99 housings .... just use that. Thank you all for the input, sucks ... but whatchya gonna do?
So with wetsanding and polishing you werent able to get them clear?
I find that hard to believe. Ive taken headlights that were so cloudy you could not seem through them at all and got them crystal clear. Started 800, then 1200, and finished up with 2000. Once they were really smooth, buffed the heck out of them.
May 28, 2009 | 06:59 PM
Quote: I wasn't aware that headlights from the 2000 Maxima worked in the 4th gen.
Shut it.
Quote: BECAUSE, the 95-96 replacments have clear glass lenses, no fogging or yellowing.
Oooh. Okay, thanks for the clarification
May 29, 2009 | 10:00 AM
If i might I just polished my headlights and it worked great. I got the 3M one like this:
http://www.repaintsupply.com/pd-3m-3...ion-system.cfm
It comes with all the stuff you need and attaches to a drill which makes it way easier.
May 29, 2009 | 11:46 AM
Quote: If i might I just polished my headlights and it worked great. I got the 3M one like this:
So ... it works well? I have tired several 'other' products, but none of them last. I have been sanding / buffing this (pass side) light for quite a while, at least several months. It keeps glossing over - doesn't seem to matter the product used. If this works for the long run, I'd gladly give it a try. $15 seems worth it, considering some of the polish alone can cost $$$$.
Good to note on the 95-97 lights .... wonder why they switched to plastic at all anyway, cost maybe?
