Boost Sensor Q ?
Old Jul 5, 2009 | 08:51 PM
slow_yota's Avatar
Boost Sensor Q ?
So when i bought my max i had to rebuild the front end and and never knew what to do or even where this guy was suppose to be..
So what does it do ?
Do i really need it ?
and where is it suppose to mount ?
The guy that i bought it from said that it had something to do with the hood props and that it made the hood light..light up when you pop the hood up...Somehow i doubt that though.
Old Jul 5, 2009 | 10:03 PM
asand1's Avatar
It mounts to the stock intake snorkel near the core support. I'd say its a MAP sensor, although I don't know why We'd have MAF AND MAP.??
Old Jul 5, 2009 | 10:15 PM
HandsonMaxima.'s Avatar
yeah its in all maximas ive seen attached to the intake.
try searching?
search says that it is a MAP sensor like in the above post
Old Jul 5, 2009 | 11:19 PM
slow_yota's Avatar
yea i searched and found some things about but really didnt get why we needed it since we already have a MAF..and most it doesnt even say its a MAP, It says Boost so..wtf ? lol...
Old Jul 6, 2009 | 12:25 AM
tosheto's Avatar
It does say on it that it is a boost sensor, but it is the same thing really (MAP). Like stated above, it mounts to the intake snorkel with a 10mm bolt!
Old Jul 6, 2009 | 08:53 AM
loxety's Avatar
how do you know if its malfunctioning?
Old Jul 6, 2009 | 09:28 AM
mtrai760's Avatar
'Trynna' is not a word
You get a check engine light.
Old Jul 6, 2009 | 09:30 AM
mtrai760's Avatar
Boost sensor = Absolute Pressure Sensor. From the FSM:
The sensor detects ambient barometric pressure and intake manifold pressure respectively, and modifies the voltage signal recieved from the ECM. The modified signal will then be returned to the ECM. As the pressure increases, the voltage rises.
If you try searching: http://forums.maxima.org/4th-generat...a-car-lol.html
Old Jul 6, 2009 | 09:42 AM
djipka's Avatar
if you get a 95 ECU you can take that shiz off. that's what I did. The 95 maxima didn't have most of the vacuum gallery that the 96-99 have and there is not MAP (boost) sensor.
my03maxima
Jul 28, 2024 07:40 AM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
