Coasting Problem
Old Jul 9, 2009 | 09:13 AM
tarheel62592's Avatar
Coasting Problem
Lately on my 1997 Infiniti I30 whenever im just coasting, no brake, no gas, no turning, i can hear this creaking noise coming from the right wheel, and i can also hear a thumping kind of noise. Everyone i have talked to says its my CV boots/axles. How can i find out and is there anything i could do to fix it without taking it to a shop?
Old Jul 9, 2009 | 09:18 AM
Foellarbear's Avatar
you can actually take it to your dealership they should just be able to look at it for no additional charges. Well thats what i did.
Old Jul 9, 2009 | 09:30 AM
pmohr's Avatar
No more Maximas...
Is this on flat road, bumpy, what?
Have you jacked it up and checked out the suspension yet?
Old Jul 9, 2009 | 09:33 AM
Feldman's Avatar
as far as my experience the dealer usually charges a base diagnostic fee which varies from dealer to dealer.
usually a cv joint will make a popping noise when you turn the opposite direction of the noise so in your case if you took a sharp left turn you should hear some popping. Since your symptoms are while you are under no load going straight i am going to go ahead and say its more thank likely not your cv joint.
In any case its not too hard to look in the wheel well area to see if the cv boot is ripped or anything else looks out of place.
If you aren't really car savvy i would use the forum to find someone in your area and then ask them if they could help you. For a free lunch i bet just about anyone on the org would be willing to help you solve your problem
Old Jul 9, 2009 | 09:42 AM
It does it on flat roads and i have jacked it up but i only know so much. Thanks Feldman, if i look in and see that nothing looks ripped or out of place, is there anything else i should be looking for that could be the possible culprit?
Old Jul 9, 2009 | 09:58 PM
Feldman's Avatar
if i had to guess i would say its a bushing, strut mount or something along those lines. I had an infiniti with a squeaky upper control arm bushing but it only squeaked when i hit a bump.
Moving in a straight line coasting on a flat, smooth road is the condition that would be the least likely to show symptoms of a problem as far as i can think. are you sure it isnt happening other times and you just cant hear it because you are under load and the engine is drowning it out?
Old Jul 9, 2009 | 10:40 PM
Im pretty sure i found out what it is. My rotors are warped slightly and they are waivering back and forth in the brake caliper which is making the noise. I just got my rotors remachined and the noise seems to have gone away.
Old Jul 9, 2009 | 11:29 PM
Feldman's Avatar
they must have been pretty bad! Glad it seems to have taken care of things though
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
