hard time finding starter mounting locations
Old Jul 19, 2009 | 06:52 AM
kasemodz's Avatar
Well, I'm trying to remove my starter, I looked at the motorvate site for instructions on how to remove the starter. I'm trying to find the two bolts that holds the starter. However, I believe I found one but was unsure about the other one. Can someone please verify these pictures and let me know if these locations are correct? If not, please let me know the correct location. Thanks.
I believe here is one of the two mounting locations
Here is the one I'm unsure about
Old Jul 19, 2009 | 07:53 AM
maximized98's Avatar
Addicted to the Org
The one closest to the firewall should have a plastic thing attached to the bolt. You should easily see the one that is on the other side. They are both pretty much straight across from each other. Don't forget to unplug it, and also to detach the wire from the solenoid.
Old Jul 19, 2009 | 10:38 AM
pmohr's Avatar
No more Maximas...
It'll be a little harder for you to get around all of the existing wire harness clips and whatnot.
MaximaRaj
27
Oct 2, 2015 07:31 AM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
Wolvee
Aug 11, 2015 12:24 PM
