Removing Fender...
Old Jul 23, 2009 | 01:11 PM
matty's Avatar
Removing Fender...
Well its time to replace the drivers side door hindges but before I go tackleing the job, I figured I would ask you guys how hard of a job it is to take off the fender and re-install it ??
I was thinking it shouldnt be too hard of a job but I thought i'd ask
thanks
matt
Old Jul 23, 2009 | 01:33 PM
petro2342's Avatar
It isn't too much work, but rather time consuming. You have to open the door and hood, plus take off the wheel well cover which connects to the bumper. 3 or 4 nuts iirc.
Old Jul 23, 2009 | 02:36 PM
pmohr's Avatar
No more Maximas...
http://forums.maxima.org/4th-generat...ml#post7022015
Quick and easy.
Old Jul 23, 2009 | 02:41 PM
MaxiNone's Avatar
goodluck, i swapped out door hinges and the door sagged even more after replacing them. adjusted them and it still didnt hold
Old Jul 23, 2009 | 07:34 PM
matty's Avatar
How come ?? Its play within the hinge, therefore if you replace them, it should fix it.
Did you do one at a time or took the entire door off and tried to remount it ??
-matt
Old Jul 23, 2009 | 11:01 PM
thomatt12's Avatar
It's a really simple task and it doesn't take too much work. Good luck!
Old Jul 23, 2009 | 11:13 PM
Flava_24/7's Avatar
Boosted Panda
-matt
Also was the door completely supported while attaching and secruing the hinges?
Old Jul 24, 2009 | 07:45 AM
C-ko's Avatar
I also took off both fenders in order to replace the hinges from driver and passanger side. It wasn't difficult at all only time consuming, as previously stated.
I thought the doors would function correctly by not sagging, but to my surprise both doors were worse than before. What i recommend u doing is adjusting ur old hinges instead of replacing them. A body shop did this for me while it was in the process of repainting.
Old Jul 24, 2009 | 11:28 AM
MaxiNone's Avatar
-matt
i took the door off completly, and my brother was holding the door while i was bolting it back on...
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
