Gas cap goes pssf - normal
Old Jul 26, 2009 | 03:20 PM
edwardh1's Avatar
99, when opening the gas cap you get a psfft noise- can t tell if its pressure or vacuum- is that normal?
Old Jul 26, 2009 | 03:40 PM
JNCoRacer's Avatar
Just the tip.
Normal.
Old Jul 26, 2009 | 04:07 PM
Feldman's Avatar
^agreed, nothing to worry about
Old Jul 26, 2009 | 04:39 PM
maximized98's Avatar
Addicted to the Org
Are you sure you are not opening a 2 liter cap??
Yea it's normal, it's relieving pressure
Old Jul 26, 2009 | 04:51 PM
Reece616's Avatar
i think it has something to do with the vapors being released in the gas tank and when you open it, the pressure that was created is released, creating the sound you hear
Old Jul 26, 2009 | 06:00 PM
fat_kid's Avatar
for real??
Old Jul 27, 2009 | 08:55 PM
Snypa's Avatar
its normal...what i dont understand though is when you go to check your gas cap and its loose as hell...then p0440.
Old Jul 28, 2009 | 08:10 PM
Madmaxima95's Avatar
I'd think its actually a slight vacuum, the air is rushing in to fill the void left by the fuel that you used???
Old Jul 28, 2009 | 10:31 PM
trand71's Avatar
Seriously? It's the left over vapors from your coilpacks number 1,3 and 5 that didn't detonate gas and it was forcefed into the gasoline vacuum line, your lucky it didn't rush back into your LIM and explode your engine...lol...you'll be ok.....
Old Jul 28, 2009 | 11:36 PM
whiteSE's Avatar
it supposed to release a little bit of vapors. i believe the gas caps are designed to hold only 2 PSI.
Old Jul 29, 2009 | 06:05 PM
???Wha??? I was talking about the void in the tank itself, you must be talking about the muffler bearing or the flux capacitor...
Old Jul 29, 2009 | 11:14 PM
jdooley's Avatar
I checked the description of the evaporative emissions control system in the FSM and it shows the gas cap as having both pressure and vacume relief valves.
Based on the description about it's operation, it seems to me any way, that if you unscrew the cap at a gas station or just just after operating the car, you should hear a vacume release (air rushing into tank) because the system is designed to prevent fuel vapors from escaping into the atmosphere so it burns them in the engine.
If the car is sitting in the sun on a hot day and you release the cap I would expect vapors to come out of the tank and it should smell, more definitely, like gas.
The FSM states that the cap should hold a pressure of 2.22 - 2.90 PSI and a vacume of just -.87 to -.48 PSI.
Old Jul 29, 2009 | 11:44 PM
Feldman's Avatar
I'm impressed that you actually pulled out some legit numbers, meanwhile the rest of us were just goofing around and being smart asses. That's good to know
Old Jul 30, 2009 | 12:06 AM
flynlr's Avatar
the gas cap on my 95gxe stopped go poooshhhhhh back in 2001 I replaced it and the evap canister + the evap purge vent control valve in 2008 which fixed the CEl but still no poooooooshhhhh,
Old Jul 30, 2009 | 03:59 AM
max ride 41's Avatar
better a smart *** then a dumb ***....uppet:
Old Jul 30, 2009 | 11:07 AM
max96imaaaa's Avatar
My maxima does it when I fill up, generally with about 1/4 tank left. My altima 2.4L never did unless it was way below 1/8 tank. Weird.
Old Jul 30, 2009 | 04:57 PM
smaller tank
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
ef9
Oct 4, 2015 08:43 AM
