Well heres the problem i have my car stalling it happened before a coule of times but then it would kuikly go away but now its different. Every time i start the car and once its on idle i mean 800-900 rpm it shuts off. Heres what my computer throwing me code 01 01 which is cam position sensor i just went through 2 brand new ones from Part Source but the code is still there. I was woundering may be its a fuel problem???
i heard some things about fuel pressure regulator
Did you check the harness that leads to the cam position sensor? If the ECU is throwing that code odds are its probably that but someone can chime in further.
I think that (in bold) may be part of the issue. OEM FTW!Originally Posted by black97
Also check MAF, maybe dying
You really haven't given a lot of info to help. Does it sputter? How long before it dies?
Is seaform a cure all for cars or something?Member
Quote:
Plus +1 here too...check for continuity on the CPS harness....you can start your car an move your harness to see if it shuts off..(this is the alternative way if you do not have a voltmeter) star with that and let us know...Originally Posted by DAVE Sz
backtrace the CPS wires all he way back to the ECU. The code is popping up for a reason...
If thats true im in a heap of trouble
Quote:
You another subscriber to the seafoam elixir? I've never used it.... is it really that great????Originally Posted by Product_Of_Korea
What happened to the OP and his emergency ?
