Maxima Died, my mods to blame?
Old Aug 15, 2009 | 10:07 AM
OC_Nooby's Avatar
So I went to start my car yesterday and when it fired up the motor was knocking like a mother. At first it was very loud just because the initial rpm jumping to 1500 rpm then dieing down. Once the rpm was steady it was a continues knocking noise coming from the motor.
Now mods wise me and my brother did:
00vi
Lighter Fywheel /Clutch (didnt even break in the clutch)
Y-Pipe
EU + ext Rev
I did extend the rev limit to 7500rpm on the stock internals which could have weakend the crankshaft bearing or somethign else inside the motor.
I Havent taken apart the motor to see the problem I was just told by about 4 people the motor was finished, which is a pain in the *** as I invested time and money.
Im getting another maxima and will transfer all this stuff over. Any suggestions on what else should be done to increase the stability of the motor like maybe a rev up oil pump and valve springs?
Ohh the motor was very close to 260 000 kms which is about 161,556 miles.
Was this bad luck or just me?
Old Aug 15, 2009 | 10:27 AM
Product_Of_Korea's Avatar
Do you have a video or a sound clip??
Old Aug 15, 2009 | 11:56 AM
OC_Nooby's Avatar
No not really, don't have the means on getting one either
Old Aug 15, 2009 | 03:36 PM
black_maxed95's Avatar
maybe you dropped a screw in the engine when doing the 00vi. Are you getting any codes? Its hard to say what happened cause theres not much info.
Old Aug 15, 2009 | 03:38 PM
Crusher103's Avatar
has it been running funny for the past couple of days?
Old Aug 15, 2009 | 03:48 PM
asand1's Avatar
Maybe after extending the rev limit you revved the pee out of it and spun a bearing.
I'm sorry, but it sounds like it may have been your right foot responsible.
Mods wont cause the kind damage your describing, but they will allow a motor to run hard and fast enough to destroy itself where it may not have before.
Did you replace rod bolts? Main studs/bolts? Did you mod the bottom end mechanically at all?
Old Aug 15, 2009 | 03:54 PM
Crusher103's Avatar
^lol on a bolt on maxima? i can answer that one. No.
Old Aug 15, 2009 | 05:12 PM
Maybe you ran lean past 7k??
Are you sure its a knock and not some timing chain noise?? Does it come rapidly or is it delayed and random?? Is in constantly making the noise or is it every say 3 secs??
If i were you and your motor happened to be shot then i wouldnt grab another maxima. Id throw in a new motor........
Also if you were contimplating on putting in a new oil pump or HR springs or whatever then you should just do a motor swap anyways just cause its alot easier doing it outside the car vs inside the bay.
Have you tried going back to stock timing and stock fuel map???
Old Aug 15, 2009 | 09:14 PM
OC_Nooby's Avatar
I had the 00vi on for a good 2-3 months.
Nope, just in the morning when I fired it up it made a noise like two squirrels fighting to the death...
No I didn't replace any of that. The car didnt knock when I was passing the 6500 rev limit, it went out on me when I fired it up in the morning
Past the 6500 rpm limit I was running 12ish afr. I'm sure it not the timing chain as the motor idles fine and if it was the chain the whole car would somewhat be affected.
The noise comes rapidly at first then maintains the constant knocking.
The reason im thinking of buying another car is because this one has some rust, the rockers are bad. Plus finding the damn motor is hard aswell.
I think all in all I either spun a bearing or something else with the crankshaft.
Old Aug 15, 2009 | 09:16 PM
GreenTea's Avatar
Low on oil? Sounds like a spun bearing.
Old Aug 15, 2009 | 09:29 PM
shadyonedeath's Avatar
what year?
Old Aug 15, 2009 | 09:57 PM
Not really. A bad tensoner will cause chain noise but not really affect the cars perfomance.(unless you skip a tooth)
People have this issue quite often with vq's and usually drive them till they die instead of changing out the tensoner.
Also have you tried going back to stock timing maps and fuel??
So i take it your performance is down or not up to par??
Old Aug 15, 2009 | 09:58 PM
OC_Nooby's Avatar
Oil was on the low side on the dip stick but not low enough for the motor to be dry.
It was a 1997 Maxima SE,5 speed.
Old Aug 15, 2009 | 10:04 PM
OC_Nooby's Avatar
By timing you mean ign timing with the EU? If so I havent messed around with that yet. Ill see if its the tensoner.
Old Aug 15, 2009 | 10:08 PM
Some things to check:
-Did EU die? wires come undone?
-Any codes?
-Did you ever rev it high when cold? (past 3k)
Also, is it DEAD...or does it actually turn over but just has severe knocks?
Old Aug 15, 2009 | 10:12 PM
OC_Nooby's Avatar
-EU is fine
-I had many codes do to not having the egr and some other stuff with doing the 00vi
-I never reved it when it was cold
It turns over then knocks like a mother
Old Aug 15, 2009 | 10:14 PM
Yes thats what i mean. Turn all your maps back to zero and see if that makes a diffrence.
Do you know where in the engine bay where the sound is coming from??
Also is your perfomance affected by this??
Old Aug 15, 2009 | 10:36 PM
if it knocks THAT bad, i doubt there's any coming back from it.
Old Aug 15, 2009 | 10:56 PM
OC_Nooby's Avatar
The sound is coming from the left side of the engine bay. I havent taken it out for a spin as I did not want to test it out and have it go on me. Once I herd this noise I basically started it another 6 times on and off to show it to my brother,dad, and a mechanic friend. Then It was towed to my brothers friends garage.
Old Aug 16, 2009 | 02:54 PM
asand1's Avatar
Thank you very much for your smart *** answer, but I don't remember directing any questions at you.
I wasn't sure whether we have bolts or studs in the mains, or what the aftermarket offering is for that matter. All I was asking, was did he do anything to prepare his bottom end for high revving?
Old Aug 16, 2009 | 02:59 PM
In OP
Old Aug 16, 2009 | 09:16 PM
OC_Nooby's Avatar
The car is going to be checked out tomorrow... gonna check what the issue is but prolly a write off.
Old Aug 17, 2009 | 07:13 AM
njmaxseltd's Avatar
Maybe after extending the rev limit you revved the pee out of it and spun a bearing. I'm sorry, but it sounds like it may have been your right foot responsible.
I too find it very funny that people think they can extend the rev's 1K over what the mfg limits without any internal engine upgrades.
Old Aug 17, 2009 | 08:39 AM
I did it w/o any issues(187k) till i hit 8k then my clutch was ate up. but on the flip side i ran it pretty rich.
Old Aug 17, 2009 | 08:48 PM
OC_Nooby's Avatar
Well, we found metal shavings in the oil...So yah. Shes done.
Was under the impression these motors where bulletproof ^_^ jk...
If I find another max what would be some internal upgrades to safely run the car at 7.5k. By safely somewhat more controlled.
Old Aug 17, 2009 | 09:44 PM
watson's Avatar
get a 5.5 gen maxima and sell me your parts
Old Aug 17, 2009 | 10:05 PM
BronxSleeperMax187's Avatar
What oil ?
halfpol
Oct 17, 2022 12:16 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Maxboy23
Aug 11, 2015 11:59 AM
halfpol
Aug 5, 2015 08:24 PM
