Can the A/C system be "flushed" properly if the compressor is not working?
Old Aug 17, 2009 | 07:55 AM
seanwn's Avatar
Title pretty much sums up my question.
I'm about to overhaul my A/C system due to inoperable compressor (ie. http://forums.maxima.org/4th-generat...or-clutch.html) I'm going to have the system evacuated so I can begin working, and was wondering if they can flush the system as well. So that I don't have to clean each individual line. And if they can do so properly. Thanks.
Old Aug 17, 2009 | 11:15 AM
njmaxseltd's Avatar
If the clutch is the only component that has failed, then you don't need to open up the system. No need to flush it either.
Old Aug 17, 2009 | 02:17 PM
seanwn's Avatar
That's what I'd hoped, but it's near impossible to locate just a clutch.
And it's been almost a year since the A/C has run, so I have no doubt I would have more problems if I were just able to replace the clutch.
Old Aug 17, 2009 | 02:36 PM
ColombianMax's Avatar
I would assume a "flush" for the A/C system would consist of draining whatever old PAG oil is in the system as well as evacuation with a vacuum to get all the moisture and air out and then recharge and add fresh PAG lube. I've never heard of an A/C system flush but then again I'm not an A/C expert, hope I answered your question
Old Aug 17, 2009 | 03:04 PM
seanwn's Avatar
A flush is just where they run a solvent/flush through the system after evacuating the system to get the internals of everything clean. So there's no contaminents or anything.
Old Aug 18, 2009 | 06:36 AM
njmaxseltd's Avatar
Still no need to flush, have the system evacuated, replace the compressor, then once again, evac & recharge.
vingodine
45
May 21, 2016 12:46 PM
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
