Idle speed at 500 at stop
Old Aug 27, 2009 | 06:45 PM
kisas's Avatar
a little bit lower than normal?
what's the possible cause? clogged EGR ? thanks!
Old Aug 27, 2009 | 07:22 PM
JNCoRacer's Avatar
Just the tip.
Got any codes?
Is the low idle something that just started recently?
Give us a little more info man.
Old Aug 27, 2009 | 07:51 PM
max ride 41's Avatar
its normal dude.
Old Aug 27, 2009 | 08:54 PM
Shift_Knob's Avatar
mine sets about 800-950 at idle and i thought that was kinda high for a 5 speed.
Old Aug 27, 2009 | 09:03 PM
EEMaxima's Avatar
What I observe:
A/C off ~ 550-600 RPM
A/C on ~ 800-900 RPM
5 Speed
Old Aug 27, 2009 | 09:17 PM
f550maranello2's Avatar
Originally Posted by EEMaxima
What I observe:
5 Speed
thats normal.. idle always goes up with ac on
to the OP
check/ clean idle control valves.. and set idle speed per sticky
Old Aug 29, 2009 | 07:13 AM
kisas's Avatar
no code, and mine is auto trans
I used to have a ford taurus v6, when I stopped on a slope, it will move up if I don't put my foot on brake. but for this car, I have to put on gas to hold on the slope. It seems that nissan has a weaker engine than ford.
Originally Posted by JNCoRacer
Got any codes?
Old Aug 29, 2009 | 07:14 AM
kisas's Avatar
my has the similar, but it drops to 500 from time to time, especially on a slope.
What I observe:
5 Speed
Old Aug 29, 2009 | 07:26 AM
hell you say, you are
Old Aug 29, 2009 | 07:28 AM
EEMaxima's Avatar
We all know hill holding is the ultimate test of engine power
Old Aug 29, 2009 | 08:40 AM
DAVE Sz's Avatar
Hooooooonda.....
its normal dude.
no it isn't. Not 500rpm and not for an auto....
Old Aug 29, 2009 | 02:57 PM
kisas's Avatar
Old Aug 29, 2009 | 02:58 PM
kisas's Avatar
a few more words about this? EGR?
Old Aug 29, 2009 | 03:58 PM
pmohr's Avatar
No more Maximas...
How would a clogged EGR guide tube (assuming that's what you're referring to, since you didn't mention anything specific) affect the idle speed? The EGR is not functional at idle.
Did the idle speed lower over time, or did it randomly happen? Did you do anything immediately prior to noticing the low idle?
Have you given a thought to properly adjusting the idle?
Old Aug 29, 2009 | 09:12 PM
i have and i have an auto and it idles at 500
Old Aug 29, 2009 | 09:48 PM
Andy97max's Avatar
I have an auto. It did idle around 500 rpm in gear at a stop (no a/c). There was a slight vibration too. Higher idle and less vibration with a/c on.
I cleaned the MAF and that actually bumped up the rpm by 100 or so. Less vibration. I am considering adjusting the idle up another 50 or 100 to completely get rid of the annoying vibration while in gear. Checked the motor mounts and everything is good.
Old Aug 30, 2009 | 07:13 AM
yeah, i will admit that the idle went down a little over the years. how often should you clean the maf??? my 95 does idle a little rough, but runs fine.
Old Aug 30, 2009 | 07:53 AM
kisas's Avatar
About EGR, a buddy on org took a look at my car and thought that might be a clogged EGR problem.
I just owned this car for 2 months, not sure what's the situation in the past. I just noticed it recently after I came back to atl where there are a lot of uphills and downhills. when the car stopped for light on a uphill, sometimes it can't hold position with gear on 'D', idle rpm was at 500. then I started paying attention to idle speed. it does this randomly, 30% of the time.
adjusting the idle speed? good point, but I need to make sure the low idle speed is a symptom of some malfunctions.
thanks for your input
Old Aug 30, 2009 | 07:55 AM
kisas's Avatar
I believe it's not cleaned in the last 60k, the previous owner did nothing to this car. I doubt he even changed oil in 3k.
Old Aug 30, 2009 | 12:51 PM
DAVE Sz's Avatar
Hooooooonda.....
might wanna fix that then.......
Old Aug 30, 2009 | 02:25 PM
nothing to fix dave, its runnin fine as previously stated.
Old Aug 30, 2009 | 07:06 PM
Andy97max's Avatar
I would clean the MAF every time you change the air filter.
Old Aug 30, 2009 | 07:15 PM
bigpulve+'s Avatar
Auto idle should sit around 550 and 650 with no a/c. May have a slight IACV clog or a vacuum line may be leaking a little. Its such a small amount that I would just adjust the idle up a bit.
Old Aug 30, 2009 | 07:23 PM
yeah, im sure at 195,000 miles that the engine runs a little rough even though i do an oil change every 2,000 miles. and, i have an k&n air filter which does need a cleaning and a respray. the idle is all the way up, so i need to do a throttle body clean out. tomorrow.
Old Aug 30, 2009 | 08:29 PM
DAVE Sz's Avatar
Hooooooonda.....
you said it idles rough...
Old Aug 30, 2009 | 08:41 PM
Coolsaber57's Avatar
I agree with the 550 and 650, but not adjusting the idle up just to cover up the problem. It could be costing you power, gas mileage, etc.
Myself, I have the same problem however, I think it may be transmission-related, as my CEL tells me something about my VSS (which I've replaced already) and something about a signal to the transmission computer.
Old Aug 31, 2009 | 08:22 AM
bigpulve+'s Avatar
welcome to the world of the p0400 code. Its a *****.
oh and a 50 rpm difference could be so many things. all of which really arent hurting the engine. Hell it could be a vacuum leak the size of a pin hole, the idle screw moved a tad, there could be a small bit in the IACV ect. Its not like hes moving it up 200 or anything.
Old Aug 31, 2009 | 09:25 AM
...until it gets worse and you adjust it up again. IMO, fix the problem, it'll just get worse.
and isn't P0400 an EGR code?
Old Aug 31, 2009 | 10:17 AM
bigpulve+'s Avatar
Oh yeah thats right it is. Ive just ignored my cel for 2 years.
Old Aug 31, 2009 | 10:53 AM
lol. Yeah, I get this feeling that one day my tranny will just explode because of this code. Oh well, it'll give me the opportunity to upgrade to a VLSD tranny from the I30.
Old Aug 31, 2009 | 11:04 AM
bigpulve+'s Avatar
Its the VSS code right.....I have that. Changed the VSS, cleaned and tighted down the terminals on the speedo. I dont think it will kill the tranny.
Old Aug 31, 2009 | 02:17 PM
DAVE Sz's Avatar
Hooooooonda.....
I have the VSS code as well on my 96 ECU. I say ecu because the ECU itself is the cause for the code...
Old Aug 31, 2009 | 02:19 PM
deezo's Avatar
I don't get your logic at all.
Old Aug 31, 2009 | 09:11 PM
Yeah, it's not that one i'm worried about it's the signal to the transmission computer CEL that has me worried.
captchaos
Mar 15, 2016 12:18 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxxx10
Sep 13, 2015 03:16 PM
