Troubling Trouble Codes P0136, P1320, 0202
Old Aug 30, 2009 | 09:04 PM
97 Max SE's Avatar
So, I have a 1996 GXE Maxima with the following trouble codes:
0201
P1320
P0136
I checked the codes using a code reader and the ECU/screw method. 0201 is likely an ignition coil, but I don't get an additional cylinder misfire code. These codes have been coming for a few weeks. Last week I changed the plugs, and the left rear cylinder as you look from the front of the car looked like it wasn't getting good spark. The other 5 looked pretty good. But why am I not getting a misfire code as well? On occasion, the car will "pulse" a bit at various speeds.
I have replaced the rear O2 sensor last winter (November 2008) from oxygensensors.com. But code P0136 indicates this O2 sensor is bad. Bummer, as I don't think there is a warranty on O2 that O2 sensor. Why am I not getting code 0707 when I check the codes with the screw/ECU method, but I get code P0136 with the OBD-2?
So should I get a new rear O2 sensor, or new ignition coil pack for that cylinder, or ?
Thanks for the help!
Old Aug 31, 2009 | 12:36 AM
haydeno's Avatar
IIRC rear O2 sensor not really important unless you need to pass emissions test.
You prob can get a used coil for like $15 in for sale section, easy way to test\ replace if it is cause
Old Aug 31, 2009 | 08:43 PM
97 Max SE's Avatar
No one else has any input? Why wouldn't the OBD-II and the Maxima error codes correlate?
Old Aug 31, 2009 | 10:00 PM
bksmax11203's Avatar
If i'm not mistaken, unless you did exhaust work to your max, you should have 3 cats which most likely should in turn give you 2 O2 sensors....so possibly the one u didn't change it the bad one?
Old Mar 20, 2011 | 12:40 PM
HomerMAC's Avatar
Donating i30 Owner
depending on cali or fed spec.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
