View Poll Results: transmission oil
0%
100.00%
Voters: 1. You may not vote on this poll
advice on transmission oil change
Old Nov 29, 2001 | 08:10 AM
eljo's Avatar
I have a 98 maxima with 62k miles on it. when should i change my transmission oil?. Should i only change oil or change the filters too?.
My rear defogger seems not working any idea how to trouble shoot that?. Thanks for your time and help
Old Nov 29, 2001 | 11:53 AM
Sonic's Avatar
You might as well flush it now, but the transmission filter DOES NOT have to be changed. Check to make sure all the 'lines' are intact on the defroster, if it isn't then you can buy a repair kit at most automotive parts store.
Old Nov 29, 2001 | 12:31 PM
eljo's Avatar
how much do u think it costs to flush the transmission oil
Old Nov 29, 2001 | 12:35 PM
mlocke's Avatar
fuse for defroster
If your defroster worked fine then suddenly didn't, you might want to check the appropriate fuse.
Sonic's Avatar
You can do this easily yourself. Under the drivers sideof the car is the transmission. Near the back is a drain bolt(14mm I think), then when loosened allways you to drain the fluid out. A total of about 4-5 qts will come out(measure how much does). Put the drain plug back in. et a funnel and take out the 'transmission dipstick' on the top of the engine. Put the funnel in there and put the same amount of tranny fluid in that you took out. The total cost should be about 10 bucks...
Old Nov 29, 2001 | 12:46 PM
eljo's Avatar
Re: fuse for defroster
I checked the fuse inside the car and it looks alright. DO i need to check any other fuse located inside the hood. i saw a relay inside the hood and don't know whether i should check that.
Old Nov 29, 2001 | 04:09 PM
Micah95GLE's Avatar
You should go ahead and have the transmission fluid flushed, which will replace all of the fluid. Merely draining a few quarts out won't do a lot of good.
Old Nov 29, 2001 | 04:23 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
http://forums.maxima.org/showthread....threadid=45742
http://forums.maxima.org/showthread....threadid=59048
Old Nov 29, 2001 | 05:21 PM
mlocke's Avatar
some questions
If one were to do the drain and fill method 4 times on a 4th gen as Bill did on his 94, approximately how much of the original fluid would be left? I did a rough calculation of ~13% if the fluid drained is 4 qt and the capacity is 10 qt but I'm not sure if these values are about right. Can the factory Nissan Matic D ATF be mixed with Dexron III? TIA.
Old Dec 1, 2001 | 06:12 AM
plrod Black 95 SE's Avatar
for around 80 bux; jiffy lube can do a 100% change; they call it t tech svc
Old Dec 1, 2001 | 08:17 AM
Micah95GLE's Avatar
The 100% change-out is the way to go, since our transmissions are fairly fragile anyway. You need it only once every couple of years, so might as well spend a few dollars more to do it right.
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
cruce91
Sep 20, 2015 10:23 AM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
