I need help with this problem
Old Sep 7, 2009 | 11:31 AM
orange57's Avatar
Ok, so i'm still getting the wobble sound from my front passenger side wheel. I hear it on the freeway, where the road bends and i'm holding steady throttle. I also get a pop at times when I release the brake.
What has been replaced thus far:
Axles, both sides
Sway bar end links
Wheel bearing and seals
Brakes and rotors
Lower Control arm
What else cold be the issue? Could this be the symptom of a faulty axle? I do have the lifetime warranty. So far everything that it has been sure to be hasn't been the issue. I'm trying to get it buttoned up as we are going to sell the car due to the purchase of a new car, and I don't want the next owner to have to immediately take it somewhere for repairs.
edit:
should i have any play in the passenger side axle between the carrier bearing and the wheel? When the car is on jacks/stands, the outter axle that goes into the wheel has a small amount of play in it, twoards and away from the wheel. It is movement in the CV portion. Does this mean the axle is shot? It has less than 2K miles on it.
Thank you,
matt
Old Sep 7, 2009 | 10:21 PM
orange57's Avatar
Old Sep 7, 2009 | 11:44 PM
asand1's Avatar
Possibly tie rods or ball joints. Have you rotated your tires to make sure its not out of round?
Old Sep 8, 2009 | 08:17 PM
orange57's Avatar
the lower ball joint was replaced with the LCA. I have not rotated the tires in a while. I will take it in for that.
Old Sep 10, 2009 | 08:04 PM
fergie's Avatar
the road bends which way...very important
Old Sep 10, 2009 | 08:46 PM
DAVE Sz's Avatar
Hooooooonda.....
any bent rims? are they balanced?
Old Sep 10, 2009 | 10:10 PM
orange57's Avatar
I've noticed it more as the road bends to the right. The tires should be balanced. I had a rotation and balance not too long ago, but I will take it in again for one. See if that fixes any of the issue.
Old Sep 10, 2009 | 11:40 PM
FallenOne's Avatar
Heres a shot in the dark, tie rods?
also im glad to see that your fixing the car up befroe you sell it, very honest and commendable of you.
Old Sep 11, 2009 | 07:46 PM
orange57's Avatar
The tie rods still seem pretty tight, there wasn't any play in them. I may look at them again though.
Old Sep 11, 2009 | 07:58 PM
DAVE Sz's Avatar
Hooooooonda.....
when was the wheel bearing replaced?
Old Sep 12, 2009 | 11:29 AM
orange57's Avatar
Wheel bearing was replaced about a month ago. I actually don't think there was anything wrong with the last bearing. It was one of those things i replaced because a lot of other people said it was definetly the wheel bearing.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
