really weird electrical problem
Old Sep 29, 2009 | 02:41 PM
LushMoney's Avatar
So a few weeks ago I had taken off my headliner and all the pillars to replace them with black, and I dyed the headliner, as well as replacing tan seat belts to black seatbelts. In addition to all this, I got new visors (one with homelink). So today I installed the headliner, pillars, interior lights, visors, etc etc and I'm getting some weird *** electrical problems. Car still runs perfect, but the clock wont illuminate whatsoever, the homelink stopped working, as well as the lights on the mirror of both visors, my radio plays fine, but antenna wont go up, and my key fob wont lock or unlock the doors. I have never ran across something like this. input or advice, or should I take it to the shop because I'm ****ed?
Old Sep 29, 2009 | 06:16 PM
Conrad283's Avatar
I need a truck
Did you check the fuses?
Were any of the problems areas you mentioned working at some point after the swap? Or not at all?
Old Sep 29, 2009 | 06:18 PM
Nopike's Avatar
You blew fuse #40 7.5A upper right hand corner of underdash fuse box.
Old Sep 29, 2009 | 08:40 PM
LushMoney's Avatar
Well I checked all the fuses and they're fine, so I dono...
Old Sep 29, 2009 | 08:41 PM
LushMoney's Avatar
everything was working perfectly fine when the car was bare while I was gathering all the parts together, now today when I installed / put everything in, this started happening. weird. Fuses are fine, but I'll see if replacing the underdash fuses will do anything...
Old Sep 30, 2009 | 06:50 AM
Nopike's Avatar
You don't need to check all the fuses, just the 7.5A one in the upper right hand corrner of the underdash fuse box. I've had many say all their fuses are fine when they are not. I would suggest you check it more closely actually remove it and check with a meter.
The only other possibilty is any wiring work. you performed but its most likely the fuse.
Old Sep 30, 2009 | 03:56 PM
JasonR109's Avatar
I hate to hijack someone elses thread but I am unable to create a new one as I forgot my old accounts email and cant log into it. I am having a very similar problem which started yesterday and is intermittent. The car runs fine but certain things don't work at all.
WORK: Engine, 12v car adapter, horn, headlights, electric seats, wipers, power locks.
DOESN'T WORK: Radio, clock, A/C, speedometer, tachometer, power windows, interior lights, turn signals, hazard lights.
I've checked fuse #40 like NoPike thought it might be but that fuse is fine. Any thoughts?
Old Sep 30, 2009 | 06:29 PM
Nopike's Avatar
Check both of you visor/vanity lights if they both work fuse 40 is fine if they are both out fuse 40 7.5AMP upper right corner of underdash fuse box is blown.
If that's not it step on the brake pedal do the brake lights go on? If yes go back and check fuse #40 if the brake lights don't turn on and the visor lights are out then fusible link "k" 75Amp is blown. I think it's located near the battery. That would mean you had a major short. How did the problem start?
Old Sep 30, 2009 | 06:48 PM
JasonR109's Avatar
I checked and the visor/vanity lights do not work and neither do the brake lights. fuse #40 appears to be fine.
The problem started yesterday randomly. I was driving along and my radio and A/C and everything else I listed just turned off. Then about a minute later it started working again. It's done this about 5 times where it will stop working but then just randomly start working again.
Old Sep 30, 2009 | 06:57 PM
Nopike's Avatar
Check 75A fusible link it's in the underhood fuse box next to the battery upper left corner. Also on the positive terminal of the battery there is a thick wire and two thinner black wires running to it (at least on my 98 SE) check that those wires are properly connected/clipped in.
Old Sep 30, 2009 | 06:58 PM
Nopike's Avatar
Also check that the battery connections positive and negative are both clean and secure.
JasonR109's Avatar
Okay I've checked FL 75. Seems its not making a good connection or something as even if I move it a little bit it result in everything turning off.
Old Sep 30, 2009 | 07:00 PM
Nopike's Avatar
BINGO!
Old Sep 30, 2009 | 07:39 PM
JasonR109's Avatar
Haha yep. I tested the fuse and its definitely A okay. Tried it in the box again and had same problem. Checked the connectors in the box and bent them a little inward and BINGO! Everything turned on, I wiggled the hell out of it and it all stayed on. Thanks again for your help. I'd have gone nuts trying to troubleshoot this on my own.
Old Sep 30, 2009 | 07:48 PM
Nopike's Avatar
Glad I could help. You should be fine but if the problem reoccurs you know where to look.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
