Problem with bolt on transmission pan
Old Oct 31, 2009 | 10:40 AM
holymoly's Avatar
The last bolt will not come off and it appears its really not a 5 sided bolt anymore. And I don't have a replacement one handy.
Sawing off the bolt? I dunno.
Ideas?
hmm, how bout a vise grip.
off to Canadian Tire to get more bolts.
Old Oct 31, 2009 | 11:15 AM
JNCoRacer's Avatar
Just the tip.
Drill it and extract it. Re-tap the threads of the hole if needed.
Old Oct 31, 2009 | 11:51 AM
trooplewis's Avatar
If you don't have anything to drill/tap with, just use a little RTV in that area when you reinstall it. The 21 bolts are so close together that if one is missing I doubt you will have a leak (yeah, one of my Max's is missing one that I torqued too tightly...no leaks so far).
Old Oct 31, 2009 | 12:01 PM
holymoly's Avatar
don't have a drill/tap, and vise wrench can't do it. RTV?
Rip the.. ? ok rtv is some plug stuff.
I had 4 liters drain from the pan so I may just bolt it back together. dang.
Old Oct 31, 2009 | 01:22 PM
pmohr's Avatar
No more Maximas...
Vise wrench? Are you referring to vice grips, or something else? If something else, then try vice grips.
Have you tried using a bolt-out (or similar)?
What do you mean 5 sided? It shouldn't ever have been '5 sided'.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
