Windshield washer fluid doesn't spray
Old Nov 13, 2009 | 04:22 PM
burgundyblues66's Avatar
It just stopped working one day, any ideas as to why.
The reservoir is full but nothing comes out when i push the spray button on the right side of the steering.
Thanks!
Old Nov 13, 2009 | 06:13 PM
trooplewis's Avatar
Can you hear a "whine" from the WW pump when you use it? If yes, your sprayers are clogged and need to be cleaned out, usually you can do it with the sharp tip of a safety pin.
If you don't hear the pump motor making noise, then you need to buy a new pump. They are about 20 bucks at Rock Auto, I have one on my workbench right now that I need to install in my 96 Max.
Old Nov 13, 2009 | 06:17 PM
bigpopaj369's Avatar
thats basically it man what trooplewis said
Old Nov 13, 2009 | 06:58 PM
bryan163's Avatar
This happened to my neighbors maxima. His pump was running, but nothing was making it to the nozzle. It turned out that the hoses and nozzles were completely clogged with bits of paper from the inside of a washer fluid jug lid. You know, that little paper disc that falls out of the lid sometimes. At least that's what I think it was.
I was able use compressed air to blow out the hoses, but I had to replace the nozzles because I couldnt get all of the paper slurry out.
Old Nov 13, 2009 | 09:10 PM
trooplewis's Avatar
Never heard of that happenng, but I've often wondered if any of it gets in oil pans or radiators or even gas tanks with the foil crap they seal bottles with.
Usually if its plugged, it's the nozzles on top of the hood that have excess wax in them from the last time you polished your hood.
Old Nov 14, 2009 | 08:58 AM
well, theres no sound at all when i push the spray button.
also, there are 4 sprayer nozzles (2 small ones for each side) and not one of them works, i dont think all 4 can get clogged at once. is there a motor or something that is responsible for the spray pump?
Old Nov 14, 2009 | 09:02 AM
sorry, i didnt see you post trooplewis, rockauto looks good for that part.
which part number is it? it gives me 4 different pumps for my car.
also, where is the thing located? is it safe to say its a problem with the pump if it doesnt make a sound??
Old Nov 14, 2009 | 01:42 PM
HandsonMaxima.'s Avatar
make sure your wires are good,
on mine i had to re pin the plug because the wires inside the plug actually were rotted and broke
Old Nov 14, 2009 | 06:25 PM
Nozama's Avatar
Grumpy old guy
Since you can't hear it it's the plug or the pump but why wouldn't all four nozzles get plugged at once?
One hose feeds four nozzles and the pump will push fluid to the place with least resistance which is always going to be the nozzles that aren't plugged right up until they plug too.
Old Nov 14, 2009 | 06:34 PM
BrettLinton7's Avatar
I love rockauto... If it's for sure your pump and there's no fuse in the system, definitely hit them up.
Old Nov 14, 2009 | 06:52 PM
where is the pump?
Old Nov 14, 2009 | 09:24 PM
trooplewis's Avatar
I'll change out mine in the morning and give you more info, but I understand that the pump has to be accessed from below the car with the cover panel removed near the oil filter. The pump shoud be just downstream from the washer fluid container.
Old Nov 14, 2009 | 09:40 PM
nitromax's Avatar
it's on the bottom of the reservoir, behind the r/f inner fender cover. check your fuses first.
Old Nov 15, 2009 | 04:25 PM
Jriv815's Avatar
I would definately check the fuse of the system first. Dont automatically assume that it is a mechanical failure. With the cars that are on the road there is more to worry about electronically than mechanically. Check the fuse, then check the plug at the pump. Check to see if there is power coming to the pump from the battery when the switch is actuated. And...if there is power and ground at the pump then using a 9 volt battery and 2 little wires, find the power and ground pins at the pump and attach the wires. If the pump doesnt do anything...then you have just found the problem.
Old Nov 15, 2009 | 08:15 PM
trooplewis's Avatar
OK, I installed a new washer pump today, It is a bit of a messy job, but not difficult; takes about 15 minutes.
I posted a mini now-to thread here:
http://forums.maxima.org/4th-generat...ml#post7297242
IN my case it was definitely the pump that was shot. A soon as I put the new one in, everything worked OK again.
Old Nov 15, 2009 | 08:27 PM
_buddha's Avatar
damn that sucks
Old Jul 11, 2012 | 01:16 AM
maxima209's Avatar
my washer "t" broke and i was wondering where i could find one?
Old Jul 11, 2012 | 01:30 AM
2brosgixxer's Avatar
Any parts store should have something that'll work. Or just pick one off a wreck at a junkyard.
Old Jul 22, 2014 | 03:48 PM
nissan99's Avatar
were is the fuse located ?under the dash ?what is it named after on 99 max...
captchaos
Mar 15, 2016 12:18 PM
02PearlSE
Feb 1, 2016 12:37 AM
fastcarny
Oct 12, 2015 07:06 AM
bumpypickle
Sep 19, 2015 01:07 AM
Maxxx10
Sep 13, 2015 03:16 PM
