Fast starting question ?!?!?
Old Nov 13, 2009 | 07:00 PM
scmaxima's Avatar
ok, so far i changed the battery and alternator, and starter
the thing is that when i crank the car, it may take it like 4/5 cranks to start. before i changed the 3 items, the car never would start untill like 15 mins of cranking >.<
sometimes the car cranks without any problems and i think its in the cold weather even! im not sure tho, what could be the problem with this? after the car starts theres no problems at all tho, and no code for any starting problem
Old Nov 13, 2009 | 07:04 PM
bigpopaj369's Avatar
when was the last time u changed ur plugs? not exacty sure but my car took a while sometimes i changed the plugs n it cleared up
Old Nov 13, 2009 | 07:10 PM
bryan163's Avatar
also try pulling the crank sensor on the front of the motor where the bell housing meets the motor and clean off all the metal shavings stuck to the magnet.
Old Nov 14, 2009 | 10:22 AM
atriuum's Avatar
you mean the starter motor? Where is the front of the motor you're referring to? I'm confused.
Old Nov 14, 2009 | 02:06 PM
chillin014's Avatar
engine coolant temp. sensor.
Old Nov 15, 2009 | 03:10 PM
nitromax's Avatar
not the starter, but the crank SENSOR, it's on the radiator side of engine.
Old Nov 18, 2009 | 08:31 AM
romicva's Avatar
Did you get this resolved?
What did you do to get this resolved.
rbuswell
Nov 17, 2016 04:54 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
Jcof88
Aug 3, 2015 10:43 PM
