Is this my IACV?
Old Nov 20, 2009 | 08:49 PM
Justaguy's Avatar
Is this my IACV?
Hi,
Okay I search and search the stickies and I get a good idea on how to clean the TB and the IAC (along with new gaskets)...call me stupid but I'm not 100% sure where exactly the IAC is located...even after looking at some pics...so I want to be certain ...
Is this where?? (The red circle)
Old Nov 20, 2009 | 08:51 PM
MaximaSpd85's Avatar
no, the iacv is the thing with the pink and purple connectors on it...
Old Nov 20, 2009 | 08:56 PM
MaxPR0908's Avatar
No..that's your throttle position sensor....you see the tube that goes from the air box and connect behind your throttle position sensor?.. where it connect, that is your IACV...Idle Air Control Valve.
Old Nov 20, 2009 | 10:46 PM
HandsonMaxima.'s Avatar
btw dont touch what you circled, it you did you have to recalibrate it.
Old Nov 21, 2009 | 07:15 AM
Justaguy's Avatar
Great Thanks..I see the purple and pink connectors.
BTW HandsonMaxima: What do you mean by don't touch what I circled...can I at least unplug to get some room?
Old Nov 21, 2009 | 09:24 AM
atriuum's Avatar
Nice. A 1:1 photo. I need a 40 inch.
Old Nov 21, 2009 | 09:26 AM
atriuum's Avatar
Em. What do you need to recalibrate if you disconnect those connections? Because I just did both TB and IACV and didn't recalibrate anything, just cleaned them and put them back.
Old Nov 21, 2009 | 10:58 AM
well you dont have to recalibrate anything if you didnt take it off.
i didnt say he had to recalibrate it if he disconnected the wires, he did, please learn to read.
by touch it was insinuated that it meant dont detach. sorry if that wasn't clear.
Old Nov 21, 2009 | 09:39 PM
thegodson1's Avatar
Dont you needa take those off to get to the valve gasket?
Old Nov 21, 2009 | 09:43 PM
bryan163's Avatar
Old Nov 25, 2009 | 06:51 PM
atriuum's Avatar
I'm trying to learn to read your typed writing, but am having trouble making out anything coherent. I'm sure it's the font.
Old Nov 25, 2009 | 09:09 PM
atriuum's Avatar
Yes you do. You disconnect the electrical connectors. Disconnect the tubes. Have a rag to catch the few drops of coolant that will come out from the coolant lines. It's covered in a bunch of threads on here, with photos. Just search for it.
Old Nov 25, 2009 | 09:20 PM
RyanJC's Avatar
Does anyone know what that vacuum hose is that doesn't connect anywhere? I was about to make a new thread, but noticed in his picture his hose not connecting anywhere either. I'm assuming it's normal?
Old Nov 25, 2009 | 09:41 PM
atriuum's Avatar
Yes it is supposed to be there. I don't know what it's called though.
Old Nov 25, 2009 | 09:50 PM
atriuum's Avatar
Originally Posted by ericdwong
...I was under the hood the other day and noticed a hose that is connected to nothing. Is this normal?
Yes this is normal. This hose is a breather hose that points down and is not connected to anything. Have no fear.
The hose is located near the large breather hose on the front valve cover. It appears to connected to the transmission at the bottom. It is a hard rubber hose that has it's open, upper end molded to face downward.
Below is where the above quote comes from. There's a lot of helpful info there besides...
http://forums.maxima.org/4th-generat...tml#post449111
Old Nov 26, 2009 | 07:16 AM
bryan163's Avatar
that's a vent for the transmission.
schmellyfart
Sep 25, 2015 04:47 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
