slave cylinder question
Old Nov 24, 2009 | 06:08 PM
se96's Avatar
I have a question does the slave cylinder normally vibrate?
I've been having issues with my clutch pedal vibrating making shifting really
annoying I checked the slave cylinder and touched it its vibrating a lot more when I pull it back is something in the trans making it vibrate or is it just going out my pedal gets stuck once in a while and sometimes it feels stronger than other times.
Old Nov 24, 2009 | 06:58 PM
aackshun's Avatar
I don't know about your vibration thing... could be something going on with the actual clutch... But did you check your fluid level? That could affect the stiffness, if it got really low maybe a bubble got in the lines?
Old Nov 25, 2009 | 08:46 AM
1trucavalier's Avatar
A slave cylinder only pushes the lever to engage or disengage the clutch there will never be any vibration. It is coming from something else and transferring the vibration through the pedal. The first culprit should be looking at your engine/trans moving like bad mounts.
Old Nov 25, 2009 | 09:48 AM
se96's Avatar
Yeah thats what i was thinking bad mounts, but ive recently replaced the clutch I hope theres nothing wrong I dont feel like doing it again. hahaha
do you know how many mounts there are? So i can check them all.
Old Nov 25, 2009 | 05:45 PM
se96's Avatar
Ok checked again let me be more specific the vibratings coming from the clutch fork where it meets the slave cylinder when I push the fork to the left which pushes on the slave cylinder thing it stops vibrating. When I pull the fork to the right away from the slave it vibrates worse. Me and my bro blead the clutch a few weeks back it was fine for about 3 days then back to the vibrating any ideas?
I appreciate the help
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
