Aftermarket coils - any good?
Old Dec 8, 2009 | 03:44 PM
BobMax's Avatar
I have some coils problems (I think... another thread). Are the aftermarket coils from Ebay or Autozone any good? Or is OEM the only way to go?
Thanks,
Old Dec 8, 2009 | 04:49 PM
EnervinE's Avatar
i has college
You shouldn't have a problem with Autozone coils, but honestly, pulling OEM coils from a junked 95-98 (not 99) would be your best (and cheapest) bet.
Old Dec 8, 2009 | 06:52 PM
QFT. It's not even hard to pull the coils.
Old Dec 8, 2009 | 07:22 PM
BobMax's Avatar
Are the earlier coils better?
My concern with used coils is that I might get another bad one and be right back in the same place.
Old Dec 8, 2009 | 08:33 PM
Nozama's Avatar
Grumpy old guy
http://www.amazon.com/s/ref=nb_ss?ur...n+coil&x=0&y=0
Old Dec 8, 2009 | 08:39 PM
EnervinE's Avatar
i has college
95-98 are the same; 99 had issues. If you're really concerned you'll get a bad egg, you can pull two of them and still pay less than you would have for a new one.
Old Dec 10, 2009 | 05:05 PM
BobMax's Avatar
How do the connectors release? I tried pulling the little green tab up and then separating the connector from the coil, and I tried pushing it down. The connector still seemed to be stuck on tight. I know they might be a little "age stuck", but it seems like something else is holding it.
Old Dec 10, 2009 | 07:51 PM
EnervinE's Avatar
i has college
You mean the wire clip? You just press the tab down (it should click) and pull/wiggle it off. If needed, take a flathead and try to "push" the connector off after getting the tab to click down. Then undo the 8mm bolts and the coilpack pulls up and out.
Old Dec 10, 2009 | 08:05 PM
atriuum's Avatar
I don't know if you've seen this already, but there may be something useful in there...
http://www.cardomain.com/ride/443899/2
The procedure is also described in the FSM in the ENGINE CONTROL SYSTEM section; the Manual can be found on the .org (some have a link to it in their signature, or just google it...).
Old Dec 12, 2009 | 11:54 AM
CosmoKramer00's Avatar
Also, remember if you cannot press the tab down, push it back in all the way again and then press the tab down before pulling it. I learned it the hard way.
Old Dec 12, 2009 | 03:01 PM
BobMax's Avatar
Maybe that's the issue I had. I'll give it another shot by pushing in first.
Old Dec 12, 2009 | 05:58 PM
cefiro a32's Avatar
EBAY Ignition coils suck
I bought an aftermarket coil on Ebay once and that thing blew out after a few minutes. I then ended up buying an oem one from the dealer for twice the price
but it worked perfectly.
Old Dec 16, 2009 | 01:28 PM
Phaedrus220's Avatar
100 posts/7 years - woot!
I recently purchased three coils for the rear bank (closest to the firewall) from DaveB; in both my 99s, those seem to be the ones that have given me problems.
Dave assured me that the problems originally seen with the 99 coils were corrected long ago, and he does not hear about problems with the 99 coils now available (still made by Hanshin). It may seem like alot (~80/coil), but given how much they impact performance, I believe it's worth going OEM over chea-bay knock-offs. You don't want a catastrophic coil failure at 5k rpm.
Old Dec 17, 2009 | 07:43 PM
Dogg's Avatar
Are there any recalls on the ignition coils? I have a '03 VW Passat with the same gimpy coil problems, and VW just got around to sending out the recall.
Old Dec 18, 2009 | 06:03 AM
internetautomar's Avatar
mod or sell?
Recalls only happen when it is a safety issue.
Old Dec 21, 2009 | 04:20 PM
Phantom 309's Avatar
www.youtube.com/watch?v=v-iM5_C9Vh0 CHECKOUT THIS VIDEO..It help me out a lot..
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
PhalC1
Aug 5, 2015 02:36 PM
