rack and pinion ????
Anybody ever had problems out of there r&p when its cold ? hard to steer when i first crank it up in the mornings. It clears up in like 5 sec though ? Curious do i need to look into replacing the R&P ? I checked the power sterring pump and all that, everything looks good in that department. Man this car is really becomeing a thorn in my side !!!!! Im fixing to sell and move on if i cant fix this issue !
Swet deal on a rack, auctions over but he always has more up
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
A fuel pump is a part on just about every car on the road.
Tight steering is a symptom which was very common on some 80's GM cars.
The fix was to replace the steering rack.
This IS NOT common on our 4th gens.
Please don't tell somebody to replace their steering rack without guiding them through a troubleshooting process to determine what could be causing the issue.
I am very interested in the answer to this as well. My car just developed the same problem. Or at least I think I am getting the same issue. When my car is first warming up there are hard spots in the steering, like it will turn easy then hit a hard spot then get easy and hard and so on and so on.
I'm not gonna say it's definitely your rack, but listed below is just some info I found, which goes along with what internetautomar said.
First Paragraph:
First Paragraph:
Common problems that afflict power racks are contamination, "morning sickness" and center wear. [...] Morning sickness is a condition where the steering feels stiff when the car is first started on a cold morning. Normal power assist does not return until the car is driven awhile and warms up. This problem is most common in Saginaw racks on older General Motors FWD cars and is caused by wear in the spool valve housing.
mikeg75
Nov 30, 2015 05:12 PM
fastcarny
Oct 12, 2015 07:06 AM
Serotta33
Sep 17, 2015 12:14 PM
