check engine light on need help
Old Jan 10, 2010 | 03:31 PM
maxxx25's Avatar
okay now i checked the codes just like the video showed and it gave me 2 codes a 0707-downstream oxygen sensor circuit slow response fault, 1302-manifold absolute pressure solenoid valve or circuit fault. is there any way u know what that is?
Old Jan 10, 2010 | 03:41 PM
flyineagle96's Avatar
seefome herr
Old Jan 11, 2010 | 10:24 AM
Fasteddie01's Avatar
Did you test the indicated problems? did you check the harnesses, O2 sensor, etc and try to determine what's causing the problem? or just write here? maybe download the FSM here http://www.nicoclub.com/FSM/maxima/
Old Jan 11, 2010 | 10:59 AM
cashoit's Avatar
use the FSM. It will tell u what to do
Old Jan 11, 2010 | 03:44 PM
maxxx25's Avatar
nope i haven't checked it yet but i was thinking that maybe i should clean the flow tube that's what i been hearing and changin the 02 sensor and the map sensor but i really don't know
Old Jan 11, 2010 | 04:56 PM
B_Eaze's Avatar
wow... wow. Why is seafoam always the answer?
nobody suggested search. do an "advanced search" in search "0707" in titles in th 4th gen section and see how many results u get. do the same for 1302. I posted the exactly what would be in the FSM courtesy of pmohr's decoder in the Noobs thread and your profile. Change your rear O2 sensor, change your MAP/Boost sensor and your done.
Old Jan 11, 2010 | 06:29 PM
maxxx25's Avatar
koo thanks for all ur help
Old Jan 13, 2010 | 09:36 AM
geraldlieteau's Avatar
This site is great
Old Jan 13, 2010 | 10:26 AM
cashoit's Avatar
Originally Posted by geraldlieteau
This site is great
noobie kiss a$$ lol
15 posts then u can start ur own thread
ANd u right this site is great
Old Jan 13, 2010 | 10:30 AM
cashoit's Avatar
The MAP is goin be a PITA cuz the bolts are located in a precarious position on the underside of the valve. The 02 sensor may require raising the vehicle. Both are at Autozone.
Old Mar 7, 2011 | 02:00 PM
philly96maxima's Avatar
Originally Posted by flyineagle96
seefome herr
LoL....I shave with Seafoam too...lol
Old Mar 7, 2011 | 02:01 PM
Originally Posted by cashoit
noobie kiss a$$ lol
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
