need help again
Old Jan 18, 2010 | 05:57 PM
maxxx25's Avatar
need help again
Well i did some work this last weekend on the g-ride i changed the oxygen sensor after the cat ,replaced the map sensor,and oil pressure sensor and the check engine light is still on i ran the codes again and its giving me the same ones and now another one its a 0302,0707,1302 so can anybody help me thanks again!!!
Old Jan 18, 2010 | 06:04 PM
internetautomar's Avatar
mod or sell?
did you clear the codes after you did the work?
Old Jan 18, 2010 | 06:13 PM
maxfever1987's Avatar
clearing the codes would be what you need to do, or after a certain miles or a drive cycle it will shut off itself, but why you have a new code after changing some sensors is odd, unless you left something disconnected
Old Jan 18, 2010 | 07:56 PM
maxxx25's Avatar
yea after i did the work i cleared the codes hoping that it would stay off ,but just a short time later it came back on and then that's when i checked it again and it gave me the other code and am sure i didn't leave anything disconnected
Old Jan 19, 2010 | 08:59 AM
mod or sell?
check wiring continuity back to the ECM. if that checks out good, I would seriously think it's the ECU which is rather a rare failure
