MEVI activation indicator
Old Jan 19, 2010 | 08:53 PM
GStrength's Avatar
I am working on a design that I am not sure has been created yet. I know that many people complain about not knowing if their MEVI is completely open, questioning the quality of the RPM switch to consistently and effectively activate the acutator on the MEVI to open the butterfly plates.
My plan consist of illuminating an LED light (indicator) once the MEVI is completely open. So far the design is in rough draft and I haven't wired anything yet, it's 11:48PM, lol too late. I plan on wiring a power wire from the fuse box to the acutator arm. I then plan on wiring a second wire from the contact metal point where the acutator arm stops against, and run that wire inside the car behind the dash leading to the LED light. The ground wire will be fixed to somewhere inside the vehicle; the kick panel preferrable.
If any insights please reply in thread.
Old Jan 19, 2010 | 11:58 PM
Quickywd01's Avatar
I think that's a good idea to be able to tell if it is working.
Old Jan 20, 2010 | 12:01 AM
aznprid972's Avatar
On a Harlan RPM switch, there is a LED light that does turn on when it is activated. You could get that and run a wire and extend the LED somewhere visible.
Old Jan 20, 2010 | 01:14 AM
killerVQ30DE's Avatar
PROBLEM its never activated for very long so you have to be quick to see it
But anyway Just run LED off your RPM switch activation wires ..
Also if you just look at the light won't tell you if the arm actually moved (ie incase of vac issue)
Old Jan 20, 2010 | 06:10 AM
GStrength's Avatar
The RPM switch always activates whenever it reaches the set rev limit. The summit RPM switch also has a light that turns green once the RPM has been reached. However from what I understand, people can't always tell if the acutator successfully opens completely and remains open, questioning the design quality that involves the RPM switch, solenoid, vacuum canister, and acutator. I will purchase the light and wiring material today and maybe try wiring it up; will post with updates.
Old Jan 20, 2010 | 11:19 AM
EnervinE's Avatar
i has college
This isn't an issue of the functionality of the RPM switch.
Old Jan 20, 2010 | 11:41 AM
GStrength's Avatar
LOL exactly what I was trying to explain in my previous reply, but you answered it so much easier. Lesson learn, be more direct and not indirect and the message is clearly stated.
Old Jan 20, 2010 | 03:29 PM
aznprid972's Avatar
ahh icic.. carry on I want to see the end product now.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
lrb6805
Sep 30, 2015 08:12 AM
dcam0326
Sep 7, 2015 07:26 AM
