Anyone had any problems with the rear brakes? (parking brake?)
Old Dec 5, 2001 | 11:02 AM
Joe_R's Avatar
I have 32K on the original brakes. Still plenty of material left. I recently developed a scraping noise from the passenger rear side. Just like the brake indicator was rubbing the disc. Took the tire off to check the pad. Seemed fine. Played with the indicator a bit, put the tier on and it was fine. Didn't act as if there was dirt in it. So I surmised maybe the parking brake mechanism was causing the pad to squeeze? Any report of the parking brake sticking on these cars?
Old Dec 5, 2001 | 02:06 PM
dwapenyi's Avatar
Re: Anyone had any problems with the rear brakes? (parking brake?)
Mine did. Same passenger side rear wheel as you. It got so bad that after a drive I could touch the rear wheel and it would be very warm. It sucked, made the car drag like a ****. I stopped using the e-brake to discourage it from happening. But one day my car rolled slightly down an incline Nothing happened, though. I promptly had it repaired after that.
DW
Originally posted by Joe_R
I have 32K on the original brakes. Still plenty of material left. I recently developed a scraping noise from the passenger rear side. Just like the brake indicator was rubbing the disc. Took the tire off to check the pad. Semed fine. Played with the indicator a bit, put the tier on and it was fine. Didn't act as if there was dirt in it. So I surmised maybe the parking brake mechanism was causing the pad to sqeeze? Any report of the parking brake sticking on these cars?
Old Dec 5, 2001 | 02:13 PM
Mad Dhan's Avatar
isnt the e-brake an shoe horn type brake inside the rotors of the rear? in which case you would not be able to see the problem.
Old Dec 5, 2001 | 02:20 PM
SuDZ's Avatar
Re: Re: Anyone had any problems with the rear brakes? (parking brake?)
I think that would be the trick that would make most of us go for the repairs.
SuDZ
Old Dec 5, 2001 | 05:45 PM
Joe_R's Avatar
I think I'll spray the spring control with some WD40. Hopefully no big deal. Just though if it was a problem, I'd take it to the dealer to get fixed before the warranty is up.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
