Help with Flywheel Selection....
Old Jan 26, 2010 | 08:02 AM
i30dvr's Avatar
ok right now i've got the fidanza flywheel which i believe ways around 12lbs.....only problem is the 4 of the PP bolts are f'n stripped so i have to take the trans back out to install a new flywheel. My question is has anyone heard of or used the Aasco aluminum flywheel. It runs about $460 and supposedly ways at only 5lbs....i know thats prolly too light for F/I but what about all motor in my case....OR should i just order another fidanza. Im kinda pissed about fidanza b/c the holes were stripped when i got it but needed a car to get down to school so i need to take the trans back out and fix it before the bolts back themselves out
Old Jan 26, 2010 | 08:09 AM
Stephen Max's Avatar
Stripped holes are easily repaired with Keenserts. No reason to throw away an expensive flywheel just for that.
I'd stay away from an ultralight flywheel if your car is a daily driver. The engine will bog easily when engaging the clutch, and engine speed control when shifting becomes erratic. You can adjust to it, but it makes driving a manual trans equipped car a lot more work.
Old Jan 26, 2010 | 08:27 AM
i30dvr's Avatar
true....i dont have any experience with repairing this kinda thing with these keenserts....u think an exhaust shop or something would know? i would obviously rip everything apart myself bc labor is crazy plus its pretty easy lol
Old Jan 26, 2010 | 08:36 AM
cashoit's Avatar
Hmmmmmm...cast iron Flywheel OR a alumiunum flywheel?????
I think i want cast iron man.
I didnt even kno they made aftermarket flywheels. Usually jus get it resurfaced or used. And i though new flywheels were cheap like 100 bucks or somethin
Old Jan 26, 2010 | 08:40 AM
I would stay away from an exhaust shop, unless you know for sure they are fairly competent.
Basically, you need to drill out the old threads with the appropriate sized drill for the Keensert you need and then retap the new hole. You need a drill press so that you can be sure the holes are perpendicular to the flywheel face. Installing the Keenserts is simple after you do the drilling and tapping.
An automotive machine shop that does stuff like flywheel and brake rotor resurfacing is probably a good bet (but not places like Autozone and Pepboys, that probably don't have a drill press). If you can't find anybody, I could probably do it for you if you wanted to pay for the shipping.
Old Jan 26, 2010 | 08:41 AM
i30dvr's Avatar
the fidanza flywheel is aluminum and dramatically increases the throttle response....idk why anyone would want cast iron other than a smoother rpm/hp curve
Old Jan 26, 2010 | 08:43 AM
i30dvr's Avatar
i would be fine with you doing it but honestly my turnaround time has to be like 2 days because im driving home for the weekend from school....what do you think a machine shop would charge to do something like this?
Old Jan 26, 2010 | 08:49 AM
cashoit's Avatar
I amend my last post. Did some research and the the stage 2 clutch and flywheel come together as a package for 400 bucks and its all heavy duty aluminium.
Old Jan 26, 2010 | 08:50 AM
i30dvr's Avatar
which clutch package are you talking about? any links?
Old Jan 26, 2010 | 09:01 AM
Probably around $50-75 labor and the cost of the Keenserts.
Old Jan 26, 2010 | 10:33 AM
cashoit's Avatar
http://cgi.ebay.com/ebaymotors/95-01...Q5fAccessories
Ebay brotha. where else lol
Old Jan 26, 2010 | 10:45 AM
cashoit's Avatar
So u and the manufacturer saying that the aluminized FIdanza reduces rotational inertia which in turns reduces stresses on the internals of the engine and makes the engine rotate faster to increase HP. So essence, an cast iron flywheel at 150 HP is rotating lets say 3500 rpm...but the fidanza at 150 HP is rotating at 3000 rpm becasue its not as heavy to rotate. Basically increasing and improving throttle response. I get that
My problem is, high grade aluminum is still aluminum. Its not as robust as cast iron.
But i get that the OEM flywheel can be like a parasitic load on the eninge and rob HP
Old Jan 26, 2010 | 12:17 PM
Flava_24/7's Avatar
Boosted Panda
I ran the Stillen flywheel which is identical to the UR and I thought it was also similar to the AASCO as well. Does the AASCO require transfering over the starter ring gear like the Stillen and UR do?
The Stillen weighed in at 7lbs naked, and with the ring gear attached it was around 10lbs.
When I ran it I was still NA, and rpms did drop much faster, I now have the Fidanza and honestly they are some what similair in my opinion.
The Fidanza weighed in right around at 12lbs and was complete, no need to transfer parts over.
Old Jan 26, 2010 | 12:24 PM
cashoit's Avatar
I thought u only need these flywheels if u runnin F/I.
Does these Aftermarkets last long?? I would love to experience the gains myself, but i dont have the resources to replace a flywheel myself and im not goin to pay for the labor to replace if they only good for a yr or so.
Old Jan 26, 2010 | 12:48 PM
Flava_24/7's Avatar
Boosted Panda
I would think they would be more benificial for NA folks who are trying to gain as much HP as they can. With the flywheel being lightweight it actually should free up a little more power then the OEM one.
cashoit's Avatar
Website for fidanza replacement friction surface
http://www.custommaxima.com/product/...e/Default.aspx
Old Jan 26, 2010 | 12:52 PM
Flava_24/7's Avatar
Boosted Panda
Yes, the aftermarket flywheels have replaceable inserts. The Fidanza insert can be had for cheaper then what CM is selling it for.
Old Jan 26, 2010 | 01:59 PM
i30dvr's Avatar
yea....i dont need the insert as the flywheel has no more than 2k miles on it.....the problem is the bolts for the pressure plate which i believe are on the outside of the replacement disk are stripped....(4 of the 8 or 9.. i need the outer portion if thats available single or just buy another. or take stephenmax idea and use keenserts...
Old Jan 26, 2010 | 09:35 PM
maxboy01AE's Avatar
i just install my fidanza and stage 3 today. but im having some issues with flywheel. the stock flywheel has a washer ( a big fat)and i was gonna use the stock washer to bolt up the fidanza but then i notice the bolts were to short. what did you guys did about it? ill try to get a pic to show you guys what im talking about
Old Jan 26, 2010 | 09:43 PM
maxboy01AE's Avatar
as you can see thats the washer im talking about. what did you do with it let me know plz im stuck with it.
Old Jan 27, 2010 | 06:57 AM
You have a couple of options. One is to get some longer bolts from your local industrial nut and bolt supply house (not Home Depot). Or you can ditch the thick one piece washer and get eight regular thin washers in order to get more thread engagement. If you do the latter, use red loctite to make sure the bolts won't loosen up over time. I've done it both ways on my car.
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
