Transmission Filter Nut won't come out!
Old Jan 29, 2010 | 11:32 AM
99NightRiderMAX's Avatar
99 Maxima, auto transmission, only nut on filter won't come out? HELP!
Old Jan 29, 2010 | 01:30 PM
smai555's Avatar
try a breaker bar
Old Jan 29, 2010 | 05:58 PM
nitromax's Avatar
don't need to remove the "filter", trust this! clean it with brake cleaner spray. i went thru the aggravation of cutting a groove in the end of the bolt so i could hold the bolt with a screwdriver while turning the nut. after all of the energy spent...duh, i realized i could have just cleaned the original as is not a true filter with mesh but just a "screen" that can be cleaned & reused. save your energy!
Old Jan 30, 2010 | 12:12 PM
Quickywd01's Avatar
On my '99 I got the nut off but couldn't get it back on and I wasn't about to remove 13 bolts to drop the VB and worry about springs flying out and ***** dropping because I was tired. The bolt is captive so you don't have to worry about it going anywhere, from what I've read.
Old Feb 2, 2010 | 03:39 PM
DBear's Avatar
IIRC, I pulled down on the bolt to create some friction between the nut and the VB) while I was turning it, and that was enough to let me get it unscrewed.
lowpost99
Oct 26, 2025 06:53 PM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
