Rear window not staying up. and its cold.
Old Jan 31, 2010 | 08:53 PM
midnight0045's Avatar
Real quick question guys.
Rear window wont stay up, it can be slid by hand up and down.
Motor works fine
whats the part I'm looking for? Window regulator?
Thanks for any help
Old Jan 31, 2010 | 09:06 PM
z32drifter's Avatar
Could be one of two things. The window regulator could have failed, the cable may be broken. The rubber bushing inside the motor may be broken. The best bet is take the door panel off and look at the regulator, if the cable is intact I bet it's the motor. The gear that drives the regulator is connected to the motor with a rubber bushing, When that bushing fails the motor runs but the window does not move.
Your other option is to buy a window regulator and motor together and just replace both.
Old Jan 31, 2010 | 09:16 PM
any best way to replace the window regulator assembly? i know there is a lot of metal showing when you take off the door panel, limiting access to the regulator. is all it is just reaching in the hole and working with limited space?
Old Feb 1, 2010 | 07:20 AM
92gxe/cg2's Avatar
Yeah its not too bad, the tight door looks intimidating at first but its not that bad. Remember which holes you took bolts out of, how things were lined up, dont pull put any door handle or door lock rods on accident and you should be fine. O and dont let the glass fall once its all disconnected...I usually tape the glass in the up position.
Old Feb 1, 2010 | 05:25 PM
angelelaine's Avatar
Must be something with Maxima's I have had two in both my rear window has been broke, on the driver side!
stevesmax
Dec 17, 2020 11:57 AM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
shaunkey1
Aug 18, 2015 10:09 PM
