Drivers Window Problem - not typical
Old Feb 7, 2010 | 05:31 AM
threej21's Avatar
ok so i did a search and went through pages and pages of threads but everyone else that has a problem with their windows has a problem with them going up.
my drivers window on the otherhand has problems going down. it also did this on my last 4th gen and was never able to fix.
ok, ill try to explain...the rubber at top of doorskin where the window goes into the door, on the inside of the window is what causes this. when you start rolling the window down that rubber will fold over making the space tighter and causing the window to drag and not want to go down. i thought i had found a solution in another thread saying to spray the rubber tracks with silicone. i did this last night and it almost seems to have made it worst.
im surprised to not find threads about this as like i said its my 2nd 4th gen to do it. could i take a razor and cut that rubber down so it doesnt touch window at all? should a glue felt or something to inside of that rubber to make it slicker and not catch?
someone please help
thanks in advance
Jimi
Old Feb 7, 2010 | 07:56 AM
smai555's Avatar
you know my car does the same thing only on some days not everyday
when it happens i roll up then put a card in there to keep it from catching, my windows are tinted are yours?
i guess felt could work ... maybe a really good cleaning and some wax on the glass? keep us posted on any tricks you decided trying i would try something my self but its too cold here
Old Feb 9, 2010 | 03:58 PM
threej21's Avatar
waxed both sides of the glass(even though only inside rubber catches) and after one day, so far so good. hasnt done it once, but again, its only been one day...will keep ya updated
Old Feb 9, 2010 | 04:48 PM
Nopike's Avatar
My car had the same problem, silicone worked for a while. That part is like $16-17. I finally changed it, had to pull the inside door off, did not take long.
Just make sure you are getting the correct part.
http://www.courtesyparts.com/maxima-...1920_1929.html
Old Feb 9, 2010 | 04:52 PM
Nopike's Avatar
I think it's this part but I forget if drivers side is LH side.
http://www.courtesyparts.com/80835q-...-p-127636.html
Since I changed it no more trouble.
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
