about those tires
Old Feb 10, 2010 | 10:11 PM
maxcima's Avatar
about those tires
hi orgers,sorry if isn't the correct forum
I came across those tires for my max 97
Definity 215 55 16
I want to know your opinion about those tires in road nose,tread life,grip in rain and snow and all ......
thanks in advace
Old Feb 10, 2010 | 10:28 PM
IlyaK's Avatar
The Golden One
Are you kidding?
This is the worst thread of the year.
You don't even provide the brand/model of the tire. lol.
WTF? Seriously?
Old Feb 10, 2010 | 10:33 PM
BronxSleeperMax187's Avatar
wont fit stock 97 rims, those are for 2000-2001
Old Feb 11, 2010 | 05:57 AM
IlyaK's Avatar
The Golden One
Yes they will lol.
215/55/16 is the size for the 16" alloys.
The 15" rims run 205/55/15.
Old Feb 11, 2010 | 06:13 AM
cashoit's Avatar
llyak ,
u mean 205/65/15. Sigh, I got hucaps lol
Old Feb 11, 2010 | 08:03 AM
mahanddeem's Avatar
Originally Posted by IlyaK
Are you kidding?
I think your response is the worst in the year
Do you know how to read ?
Old Feb 11, 2010 | 08:05 AM
mahanddeem's Avatar
Are you familiar with the Maxima 4th gen 5-spoke wheels ?
and for the OP,I don't know about that rubber,maybe some one knowledgeable will chime in
Old Feb 11, 2010 | 08:24 AM
aackshun's Avatar
Who's also a mind reader too...
(Might be the worst thread of 2010)
Wrong forum, incomplete description, and poor grammmarrrrrr
Anywho, to the OP (Original Post(er)) tires come in various sizes, this system goes like so... Width / Height / Rim Size, off the top of my head I can't tell you how to convert to inches or so, but that doesn't matter, what you should know is that the wider the better, but the stock rims can only go so wide... For the height, the more height you have the more comfortable the ride is (absorbs more bumps, etc). Rim size? That should be obvious. You will need to tell us the brand, cause each tire manufacturer has a different way of putting rubber to the road. Since you mentioned grip in the rain or snow, you're looking for an all-season tire (since you only have 2-3 months of winter left). So on these tires, write down any words you see on it... Like "Ventus" or "Potenza" or anything... Then goto google.com type it in and read away... If you're lucky, the tires you have are on tirerack.com and they have a nice rating/review system.
Old Feb 11, 2010 | 08:33 AM
balkan's Avatar
What are you talking about? OP mentioned a tire SIZE and BRAND, not anything else about it.
How can we comment about "road nose,tread life,grip in rain and snow and all" when we don't know the model and whether they're summer, winter, all-season, etc?
Old Feb 11, 2010 | 08:44 AM
IlyaK's Avatar
The Golden One
Originally Posted by cashoit
llyak ,
Typo... *hides* lol. I haven't had hubcaps or the honeycombs in a good 4 years. I'm allowed to be off by 10 on the height hah.
Please re-read his post again.
He found tires that are 'definitely' 215/55/16. Okay? And? We don't know the brand, model, season, price, condition, etc.
Worst thread of the year. My response was right on point. I've been here a while, it's not rocket science when it comes to how to use a forum. Would you go into a store and ask that question? Doubt it. Don't ask it here (in that manner). English isn't THAT hard of a language to master. I'm a f'in immigrant and I post more coherently than half of the Americans in this damn country.
+1. Well said.
Old Feb 11, 2010 | 10:13 AM
nodora97's Avatar
Definity 215 55 16
thanks in advace
Not the best tires IMO try michelin for best ride noise and etc.
Sorry Ilyak, Pep boys brand IIRC.
Old Feb 11, 2010 | 11:21 AM
mahanddeem's Avatar
+1. Well said.
you're looking for disputes ,theories and " ..it"....he asked a very simple question,maybe he doesn't know much about tires....Definity is one of Pep boys brands,if you don't know an answer for his question,don't initiate fights around......
this thread is turned into a real headache
Old Feb 11, 2010 | 11:49 AM
IlyaK's Avatar
The Golden One
That doesn't change the point that we're trying to get across.
I thought he was trying to spell 'definitely' lol. Okay, so I admit I didn't know of that brand. But that is irrelevant since no one can help him until he provides us with specific information.
Old Feb 11, 2010 | 11:50 AM
Goomz's Avatar
Definity 215 55 16
thanks in advace
since they are a pep boys brand of tire, i'd go there and ask them about road noise and grip in rain and snow. tread wear in a nutshell is: the higher the number, the harder the tire, and the lower the number, the softer, or stickier tire. i.e. treadwear 200 (which is stamped on the sidewall of the tire) = a soft, sticky tire, but be careful, these wear down a lot faster than a tire with a treadwear rating of 300.
Old Feb 11, 2010 | 11:54 AM
Goomz's Avatar
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test surfaces. As of 1997, the traction grades from highest to lowest are "AA","A","B" and "C". A tire graded "AA" may have relatively better traction performance than a tire graded lower, based on straight-ahead braking tests. The grades do not take into consideration the cornering or turning performance of a tire.
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A","B" and "C". The grade "C" corresponds to the minimum performance required by federal safety standard. Therefore, the "A" tire is the coolest running, and even though the "C" tire runs hotter it does not mean it is unsafe. The temperature grade is established for a tire that is properly inflated and not overloaded.
Old Feb 11, 2010 | 11:57 AM
MorpheusZero's Avatar
Luckily, nobody cares what you think.
Thanks for your meaningful contribution.
215/55R16 is the right size for SE 16s, but you're not going to get an accurate description of a pep boy's tire (or most likely any tire) from a pep boy's tire salesman. Really, I thought that would be pretty obvious. I'd stay away from pep boys tires in general, get something decent. Tires are important, don't ride on crap.
Old Feb 11, 2010 | 11:59 AM
Goomz's Avatar
in essence, it would be your most productive bet to buy a tire with a treadwear rating of 300, temp rating a and traction a.
Old Feb 11, 2010 | 12:02 PM
I think you are a bit too vested in tire manufacturer's ratings/claims. Treadwear is really the only thing that's meaningful, any tire worth a damn is going to have A/AA traction rating but that really doesn't tell you crap about how the tire handles. Treadwear isn't even technically comparable between manufacturers, it's really only good to give you a ballpark idea of how long the tire should last.
Old Feb 11, 2010 | 12:06 PM
Goomz's Avatar
im only providing some facts on tires lol
Old Feb 11, 2010 | 12:07 PM
IlyaK's Avatar
The Golden One
My suggestion is read reviews on Tirerack.com. I wouldn't buy a no-name/store brand tire. But that's just me. Those brands are usually like what? $80 a tire? They are that cheap for a reason.
I only trust Bridgestone, Dunlop, Kumho, Toyo, and Michelin. But that's just me, personally speaking.
Old Feb 11, 2010 | 01:19 PM
mahanddeem's Avatar
you should live in the desert alone (and consider leaving this forum) if you don't think sharing thoughts is useful....
Old Feb 11, 2010 | 07:54 PM
See previous response.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
