Car Won't Start
Old Feb 19, 2010 | 09:33 PM
maXspeed96se's Avatar
Car Won't Start
after i got my clutch replaced last week, the car has been kinda hard to start most of the time. sometimes it would start just fine but recently it wouldnt start at all. it is getting fuel as i can smell it coming out of the exhaust. plugs are NGK Irridums, might have 10k on them. also used the starter fluid and nothing. i was able to get a video of what its doing.
Old Feb 19, 2010 | 09:49 PM
Rood's Avatar
Get the starter tested
Old Feb 19, 2010 | 10:18 PM
thats my first plan to do tomorrow then check the grounds. after that i dont know
Old Feb 19, 2010 | 10:24 PM
usurped's Avatar
Hi, just throwing my 2 cents after 2 days getting my 97 SE auto running. It would crank and run great, then next time rattle and make horrendousnoises and no start. Tried a nedw battery and same thing. Found the starter would intermittanly drag huge and be too much for the battery to start.
Got a new starter with 2 year warranty, charged up the battery, new fuel filter (can't recall last change) cleaned really dirty K&N air filter, and turned the key. Started immediately. Drove for awhile till warm and then hammered it. Like a new car!!!
hth
Old Feb 19, 2010 | 10:42 PM
aic96max's Avatar
sounds like your starter is trying to turn, hence the engine noise, battery sounds good too. why not take it back to the shop to make sure there isnt any loose wiring anywhere. doesnt seem to be a battery or starter issue (engine is turning)
Old Feb 19, 2010 | 10:47 PM
hth
yeah its getting fuel. hopefully its only the starter
EDIT: or ground
Old Feb 19, 2010 | 10:59 PM
didnt have a shop do it. could this be because the matting surface between the block and tranny werent sanded down? i heard a guy with a 5th gen did the same thing and it fixed the problem
Old Feb 20, 2010 | 05:33 AM
travis01's Avatar
yea sounds like the starter!
Old Feb 20, 2010 | 07:38 AM
Snypa's Avatar
I can be wrong, but i just dont think its the starter. To me it sounds like its doing its job and something else isnt....in order for the car to fire up.
Old Feb 20, 2010 | 09:04 AM
luke95gxe's Avatar
run a ground wire from negative on battery to the bolt on the starter that holds it to the transmission sounds like after u did your clutch its not grounding right on my transmission i had a lil rinkydink ground from the frame to tranny replaced and all is well
Old Feb 20, 2010 | 05:00 PM
just got back from O'Riley's and got the batter tested and it passed. cleaned the cam position sensor and sanded down the grounds for the starter and still nothing
Old Feb 20, 2010 | 05:10 PM
luke95gxe's Avatar
just got back from O'Riley's and got the batter tested and it passed. cleaned the cam position sensor and sanded down the grounds for the starter and still nothing.
have you checked ects? they have been known to cause hard starts and stalling as a matter of fact i started my car today and it took several tries and and pumping the gas to get her started i popped the hood and the connector was lose i pushed it all the way down on the sensor plugged it all the way in an it started right up
Old Feb 20, 2010 | 07:50 PM
aic96max's Avatar
id check and run an extra ground as stated above. im not a believer of the whole mating surfaces deal, especially since it was a clutch job, not like you swapped a tranny from a junkyard with rust.
Old Feb 23, 2010 | 07:29 AM
cashoit's Avatar
add a ground from the neg battery terminal to the transmission housing
Old Feb 23, 2010 | 03:59 PM
JAY25's Avatar
More then likely is the starter!!!
Old Feb 25, 2010 | 12:39 AM
starter passed the test too. i do have a warranty on it but it would have to fail in order for me to get another one
Old Feb 25, 2010 | 11:52 AM
cashoit's Avatar
yo man...sometimes when ppl replace the clutch, they forget to sand the mating surfaces and it makes a bad ground. Add an extra ground to the transmission housing. PM Smai, he will tell u. If that dont work then that CKPS POS might need to be inspected for fouling, cleaned and/or replaced.
Old Feb 25, 2010 | 12:41 PM
who?
Old Feb 26, 2010 | 06:36 AM
luke95gxe's Avatar
Old Feb 26, 2010 | 08:31 AM
cashoit's Avatar
Originally Posted by luke95gxe
THats the way
Old Feb 26, 2010 | 09:08 AM
luke95gxe's Avatar
cable cost like 6 bucks at advance auto
Old Feb 26, 2010 | 08:56 PM
thats what up bro. thanks
Old Feb 26, 2010 | 09:43 PM
BlueBlackMax's Avatar
You said the clutch was recently replaced? Check and properly adjust the pedal freeplay make sure the clutch is fully disengaging when you go to try and start it
Old Feb 26, 2010 | 10:13 PM
GMAX86's Avatar
Is your clutch peddal stif or spongy...iam asking cuz when I got my clutch changed on my 95 max it did the same thing...turned out it was my slave cylinder... I replaced that then my peaddal got a little stiffer witch help it kick over...after a couple of weaks I had to replace the master pump cylinder witch is near the brake cylinder...but it was worth it... it ran like a dream after that...
Old Feb 26, 2010 | 10:36 PM
didnt mess with the adjustment at all. it started fine for the first day or so and then it just got worse and worse from there.
Old Feb 26, 2010 | 10:37 PM
feels normal. i can bump start it and it will drive fine. problem is just getting it to start
Old Feb 26, 2010 | 11:06 PM
Well it cant hurt to check it just grab a ruler, maybe the person who did your clutch didn't adjust it right. Also, some clutches need adjustment after the first 1500 miles
Old Feb 28, 2010 | 06:54 PM
good news
i got the car started. it was the ground. i went to advance and got a negative battery ground and grounded it to the tranny and it started right up
thanks everybody for the advice and thanks luke for the pics. that exactly what i did and it works great. thanks bro
Old Mar 1, 2010 | 05:22 AM
luke95gxe's Avatar
good news
glad it worked out for u no prob on the pics gla i could help
Old Mar 1, 2010 | 06:31 AM
cashoit's Avatar
nice!
another win for the org
Old Mar 1, 2010 | 11:46 PM
sinistermaxima96's Avatar
hey i have the same problem i jsut got my clutch done and now my car is doing the same thing were did u run the ground from the tranny to the negative from the battery?
Old Mar 2, 2010 | 12:17 AM
whiteSE's Avatar
this should seriously be stickied. i seen numerous threads about this. ima shoot a admin about this.
Old Mar 2, 2010 | 06:51 AM
cashoit's Avatar
See pics above.
Jus run a wire from the negative battery terminal to a transmission housing bolt. Any bolt will do.
Old Mar 2, 2010 | 11:53 AM
luke95gxe's Avatar
See pics above.
make sure the sand where the wire is going to make contact a wire brush will do
Old Mar 2, 2010 | 11:32 PM
thanks alot ppl i did it and it worked
Old Mar 3, 2010 | 01:36 AM
glad we could help
Old Mar 3, 2010 | 05:29 AM
luke95gxe's Avatar
glad we could help
got to love the org
Old Mar 3, 2010 | 07:08 PM
got to love the org
of course
Old Mar 4, 2010 | 03:54 PM
keil's Avatar
i just finish puting in a light weight flywheel and new clutch,and now da car is thombleing but won't start,i tried da ground thing still nada,can i have some input {plz} bfor i take every thing back down .
Old Mar 4, 2010 | 04:44 PM
luke95gxe's Avatar
there is a sensor that bolts to the tranny check that to make sure it not dirty and conected that will cuz a no start
