can't get my cornering lamp out
Old Mar 5, 2010 | 08:47 PM
ivorton23's Avatar
well i'm trying to put amber bulbs in my cornering lamps but can't get them out. i took that one screw out and it shifts but won't slide out. what do i have to do? i'm trying my best not to break them.
Old Mar 5, 2010 | 08:58 PM
nismomaxgtr18's Avatar
You have to pull the lamp real hard! lol putting Amba Lamps.
Old Mar 5, 2010 | 09:00 PM
MaximaSpd85's Avatar
dang, good luck, they are a pain in the buttox to remove, but yeah, just pull hard
Old Mar 5, 2010 | 09:33 PM
Goomz's Avatar
try to slide a panel popper or a flathead screwdriver w a folded paper towel and try to pry it near the bottom.
Old Mar 5, 2010 | 10:14 PM
ivorton23's Avatar
yeah amber bulbs... since i cant get no blue ones around here lol...went to napa to buy blue turn signal bulbs and the guy said he never seen blue ones before. jus straight up weird. got blue sidemarkers though.
Old Mar 6, 2010 | 09:46 AM
eFLO's Avatar
not sure if you've got it or just gave up but here's a tip: try spraying wd 40 on the little ball joint. on my drivers side i pulled so hard that the plastic just broke and the balljoint did not separate. on my passenger side i sprayed wd40 and it came out much easier, and more importantly, intact. good luck!
Old Mar 7, 2010 | 04:42 AM
ajm8127's Avatar
I find it easiest to use a long standard screwdriver and stick it down in between the shoulder on the little ball and the metal. Gently twist it to get it loose, then it should almost fall out in your hand. A flashlight helps.
Old Mar 7, 2010 | 01:03 PM
ivorton23's Avatar
man i just gave up...its too freakin hard to get out. that ball joint thing is a pain in the a**!!
Old Mar 7, 2010 | 01:40 PM
maxboy325's Avatar
Just get alil physical, they will pop out. If you let this stop you you'll never mod your car.
Old Mar 7, 2010 | 01:47 PM
ColombianMax's Avatar
You're simply afraid of breaking it... I was too and I said **** it and yanked and it popped out without breaking. Its just a ball-socket type tab. Just make sure you did remove the phillips screw on top
Old Mar 7, 2010 | 02:13 PM
After you get the top screw out, stick a flat head between the headlight and the corner light. Pry gently so that the edge of the corner light that is nearest to the headlight moves away from it. It will make a loud popping sound and will come out. Try searching on the forum though. Might be able to see the other techniques other people used.
Old Mar 7, 2010 | 07:35 PM
ivorton23's Avatar
ill try again tomorrow. almost got the driver side light out.i had it out where i could've yanked it out but chickened out. the one on the other side is more difficult to get out.
Old Mar 10, 2010 | 06:40 AM
cgar's Avatar
I had the same problem yesterday but since the lens is already cracked, I figured I would just muscle it. I thought for sure it would break but popped out ok.
Now onto my problem... since the lense was cracked it would sometimes fill up with water. The water caused the bottom mounted 1157 bulb socket to rust out so when I put in a new bulb it won't work. I tried to take a wire brush to it but still no go.
Any idea where I can get a new bulb socket? I already found a new lens to order so the problem won't happen again.
Thanks.
Old Mar 10, 2010 | 08:22 AM
cgar's Avatar
Here is a link to the lens that I am look at... Does it look like it comes with the new socket/bulb?
http://cgi.ebay.com/ebaymotors/ws/eB...d=170445199716
Guess I can wait until it arrives but would rather know if I can stop looking.
Old Mar 10, 2010 | 09:37 AM
98nismomax's Avatar
it looks like it does in the picture, and it even says it comes with a bulb and wire harness.
Old Mar 10, 2010 | 11:09 AM
ivorton23's Avatar
well haven't tried it again yet...been raining alot so i gotta wait til its nice out again. I'll try Eflo's idea and spray some wd40 on that balljoint thing and see if it works.
03VQMAX
Oct 2, 2016 09:36 AM
03VQMAX
Nov 10, 2015 03:39 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
conansriver
Sep 16, 2015 12:17 PM
