Nasty, metallic clanking from rear - goes away when brakes applied.
I've had this problem since I had four new tires put on when I bought the car in winter of 2008. At low speeds over most pavement surfaces (anything except glass-smooth) a clanking can be heard from the back of the car. I had no clue what it was for quite some time, but recently I discovered that if any brake pressure is applied, all the commotion stops. Any idea what this is? I assume it's related to the brake calipers. A google search said something about a missing "anti-rattle spring" being the culprit. Any ideas guys?
I brought it back there before I realized that the noise went away when the brakes were applied. They ended up shortening the mounting screws on my rear license plate, installing new wiper blades and charging me $40. Nonsense.
Crooks man, crooks. Where did u take it?
Do a search for suspension or lowering kits. There is a member who is a wicked suspension guru. I forget his name and he hasnt been on for a coupla wks. I wd say PM him. Ima try to find him. PM IIyak too, he may have an idea.
Edit:
Here is the thread: http://forums.maxima.org/4th-generat...ht=jedi+master
He is Djfrestyl. PM him, he may have an idea or check FSM for ideas.
I thought I'd reply to say that my 3-year-long saga is finally over.
The rear brake clips needed to be replaced. That's it. A 5 minute, $30 fix. My Maxima no longer sounds like a frontier-era chuckwagon rattling into town when I drive around.
Huttig2009
Sep 25, 2015 03:31 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
