HUGE CAR PROBLEM!!! FAST ANSWER PLZ!
The black and orange O-rings are not "seals", they are O-ring gaskets. The seals that go bad are the shaft seals, they look like a crank main seal or cam seal and are not replaceable.
If water is coming out the weep hole it means the Shat seals and bearings are toast and the whole pump needs replaced.
Also I did not see mentioned that pouring cold or ambient temp coolant or water into an overheated motor WILL crack a block or head unless your very lucky.
As well, exhaust gasses can enter the cooling system without any other symptoms, some shops have a tool to check the radiator for exhaust using a dye solution.
Good luck, but be prepared to find more problems.
HEY QUICK QUESTION
should i also buy a thermostat assembly like this:
http://cgi.ebay.com/ebaymotors/OEM-N...#ht_1978wt_939
or will the thermostat replacement alone be enough
uhhooo.. if your talking about black smoke It's possible that you have damaged your engine because black smoke only can have two symptoms from this, It could be oil burning or the gas is getting burned. Just to make everyone including yourself reliefed about the headgasket issue, try checking the oil dipstick check the color of the oil on the dipstick and make sure it's clear oil color or dark black dirty color, avoid the milky white color on the oil dipstick. I know needing a new engine or tranny really sucks.
Oil being burned will be blue smoke, not black. Look at the smoke from you 2 stroke weed whacker next time your running it. Black smoke is a very very rich Air/Fuel Mixture
HEY QUICK QUESTION
HEY QUICK QUESTION
You have all of the knowledge you need to do this, just go out and do it!
If you do everythin per the FSM then u shd be fine. Plus u got us for pointers. Jus DONT drop anythin in the timing chain cover and remember that timing chain tensioner is gonna spring out and u WILL need to hold that down somehow.
If you DO drop the spring and piston from the timing chain tensioner into the timing cover, it may not be the end of the world.....if you're lucky. It happened to me when replacing the TC tensioner. I wasn't careful enough about keeping the assembly together after loosening the mounting screws. I was lucky enough to fish out the parts with a mechanic's magnet that has an extension handle. Very lucky.
I've been having a leaky radiator lately. i usually have to top it off with about a quarter jug of 50/50 every two to three weeks. Just the other day i found that the leak was coming from the top left corner where the plastic top meets the rest of it. i just ordered a new one and will be installing it as soon as it arrives. its quite a simple job as long as you take your time.
i just replaced my radiator and the leak was comming from the top of the radiator.. where the plastic meets the aluminum.. i replaced the radiator and dat was it.. but if ur cap to the back up tank is cracked.. its losing pressure and probably coming from there too..
its all dried up and nice now. ill take pics first thing tomorow! youre gonna see how good it looks =] actually i have some pics from the second day i got it.
quick question though, i need to compound it then polish and wax. where should i be going?
i hate the altezas =/
heres the side, the car wasnt even car washed yet, the day right after the paintjob
sortof dusty hood
the front side. remember not washed yet
So yes thats the "$190" paint job, might not be the best ever but definitely a 100000000x better than the way the car looked before!
now the question is how can i bring life to the car =]
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
