EVAP EGR VSS KS - HELP!!
Hey guys - so I just ran the ECU in diagnostic mode and came back with 4 error codes - EVAP EGR VSS and KS -
I have replaced the KS and VSS so I don't know why those codes keep coming back... possibly a wire harness'??
VSS -
(Replaced)
I have also taken apart the gauge cluster and cleaned literally all of the contacts with electronics cleaner but that didn't seem to fix the VSS code.
KS -
(Replaced)
I have also cleaned the contact points between the KS and the block to no effect.
Regarding the EVAP and EGR - I'm just wondering where I should start first? what (if anything) is the general culprit for either the EVAP or the EGR? any help would be greatly appreciated.
VSS -
(Replaced)
KS -
(Replaced)
You may need to replace the printed circuit board on the back of the cluster. I had both the original one and a junkyard one both go bad, causing a P0500. Of course it could also be a fault in the harness somewhere, or the speedometer assembly itself.
shilov
Feb 19, 2024 09:40 PM
tseng1023
Oct 15, 2015 08:30 AM
