VQ35 swap, why am i running so damn rich?!?!?!?
Old Apr 5, 2010 | 08:53 PM
riccohou's Avatar
so after the swap i thought my gas milage would go up, but it dropped, HORRIBLY!!!!
my exhaust fumes smell like straight gas, i backfire alot, and a full tank last me about 220 miles if i always shift at 2.5k.
i just gave it a full tuneup, minus the fuel filter cuz advance auto didnt have it in stock.
wtf is up? anyone else running crazy rich?
Old Apr 5, 2010 | 09:18 PM
MoncefA33's Avatar
You need a piggyback controller and wideband to tune the air/fuel ratio, since you're running VQ35 injectors it will run richer.
Old Apr 5, 2010 | 09:20 PM
MaximaSpd85's Avatar
+1, what he said....mr "i have math to do"
Old Apr 5, 2010 | 09:21 PM
MoncefA33's Avatar
working on it...
Old Apr 6, 2010 | 01:12 AM
aackshun's Avatar
A. I thought you wrecked your car?
B. Get a Z32 fuel filter (Doesn't matter TT/NA)
C. Don't know how you got away w/o tuning it before, but obviously you're not as lucky as Jose is... Jose (Too many Jose's...)
D. Even I'm running rich.
Old Apr 6, 2010 | 01:23 AM
Eg2707's Avatar
would love to have a 3.5 in my maxima
Old Apr 6, 2010 | 01:40 AM
mastercater7's Avatar
VQ35 FTW
Turn down your fuel pressure, if you have an AFPR that is...
Old Apr 6, 2010 | 03:12 AM
bkbajan's Avatar
check for vacuum leaks also..
Old Apr 6, 2010 | 06:04 AM
Shift_Max's Avatar
Do you have a wideband to see what your a/f ratio is?
Old Apr 6, 2010 | 06:29 AM
LONERANGERSR20's Avatar
if ur evap is not hooked up, u may wanna block off the evap hose, thats wat i had to do
Old Apr 6, 2010 | 11:07 AM
urmab's Avatar
3.5 L injectors run richer, Like it was suggested get a piggyback and a wideband that should fix your issues. All 3.5 swaps run rich including mine.
Old Apr 6, 2010 | 02:59 PM
ajcool2's Avatar
Yeah you have to tune the car after the swap. My girls car was in the 10's at one point.
Old Apr 6, 2010 | 03:08 PM
AlexxSCM's Avatar
how much did it cost you guys to get the engine swap?
Old Apr 7, 2010 | 03:55 AM
Remminator's Avatar
OK, what is a piggyback and wideband? Excuse the noob, but could you please clairfy with correct nomenclature and/or brand names of such devices. Thanks. I'm about to drop in my 3.5 and I'm a little apprehensive about all these rich problems that I've read about. I am going to be using an AFPR, will this eliminate need for piggyback etc.?
Old Apr 7, 2010 | 04:31 AM
KRRZ350's Avatar
What's your fuel pressure? Run about 34 @ idle with vacuum line connected & it will be pretty damn spot on, enough that you can get it perfect with an afc if you want to but almost won't even need to, at least not right away or it being a necessity. If you run it to rich and try to pull to much via a piggyback maf tune you'll be chasing your tail anyways, so drop that FP way down first.
matts95max
Apr 23, 2025 10:44 AM
captchaos
Mar 15, 2016 12:18 PM
nbstriker10
Sep 4, 2015 04:26 PM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
