Anyone know where I can buy struts/springs pre-assembled?
Old Apr 8, 2010 | 01:21 PM
3 point slow's Avatar
Hey, guys. Havnt been on here in a long time. The maxi is getting up there in miles (165k). I need to replace some H&R springs and struts. Love my current ride height so I dont want to go stock. Anyone know of a place that sells spring/strut combos pre assembled? Trying to get H&Rs paired with KYBs.
Shoot me some links or some good prices. Also, need some drive axles. I checked the sponsors forum but its tricky to find somebody selling pre matched sets.
Old Apr 8, 2010 | 01:40 PM
njmaxseltd's Avatar
Why do you want to replace the springs? They don't ware out, per say.
You also do not need any special tools to install H&R springs on the struts. The lower stance spring does not need to be compressed much (body weight is enough) to get the strut assembled. The help of a friend makes is easy.
If you pair the H&R's with Tokico Illuminas, you'll get a much better ride then with the KYB's which are on the harsh side.
Old Apr 8, 2010 | 01:45 PM
Hmm...why the hell did the mechanic say the rear springs where "broken"? It didnt make sense to me cause I always heard that springs you really should never have to replace. You just reinforced my suspicion. Dont you need a spring compressor on the fronts, at least? If not, thats great news cause Ill just pick up some struts/shocks and would love to save money on springs to put towards the drives axles. Imma go price out the tokicos now.
Thanks!
Old Apr 9, 2010 | 08:18 AM
8ender's Avatar
If you still wish to replace springs and struts as one unit after looking it over take a look at Monroe QuickStruts:
http://www.monroe.com/products/quickstrut.asp
I've used these before and they're great. Turns struts into a hour or two job at most. The springs probably aren't really needed but by the time you buy new struts, mounts, and spring compressor you're probably up to the cost of a set of QuickStruts anyways.
Only problem with them is that the struts themselves are usually some form of Monroe Sensa-trac, which is softer and floppier than the much preferred Reflex line.
Old Apr 9, 2010 | 08:40 AM
maximized98's Avatar
Addicted to the Org
Monroe on the max is junk!!!!!!!!!!!!!!!!!!!!!
Old Apr 9, 2010 | 10:11 AM
RA021526's Avatar
If you want pre-assembled shocks/springs, get the Monroe Quick strut. I wouldn't recommend it otherwise. Why do you want pre-assembled suspension though? You can borrow the tools from the local part store (with a deposit) and do it yourself. As long as you're careful and use common sense you'll be fine. You'll probably get a good ride out of using decent shocks/springs instead of the Monroe stuff.
Old Apr 9, 2010 | 10:31 AM
njmaxseltd's Avatar
Nope, just have a buddy put some pressure on the upper perch while you get the top nut started. Same for the rears, however it you go with the Tokicos, the shaft is slightly longer on the rears which makes the rear springs EZ as can be to do yourself.
Good luck with your project, let us know how you make out.
Old Apr 18, 2010 | 12:03 AM
theWalkinator's Avatar
You can get spring compressor for $10 from Harbor Freight if there is one close by: http://www.harborfreight.com/cpi/cta...temnumber=3980
Old Apr 18, 2010 | 12:31 AM
S1cTech's Avatar
but not their pads and Rotors.
Trust me those are good, but yeahhh I dunno about suspension. lol I get iffy on stuff like that. Is like I don't want A samsung Motor. but I do love my new bigscreen samsung HDTV. lol
Old Apr 18, 2010 | 03:27 AM
ColombianMax's Avatar
www.shox.com usually sells various options/combinations at decent prices. Not sure if they're mounted and ready to bolt up but I'll let you do that research now that you have a hint.
I dont know about that... I just dropped my car earlier today and I was able to do that for the rear with help of my g/f putting the nut on while I put some weight on the spring but for the fronts I DEFINITELY needed Strut spring compressors.
EWWWWWW, I think he wanted performance oriented products though
HATERRRRR
I don't know if I'd feel comfortable using a $10 spring compressor from HF... just knowing its a cheap tool and can possibly risk your life if it were to fail is scary. I can understand getting a cheap impact gun or screw drivers but I'd personally be scared to use cheap spring compressors
I had no idea Monroe made brake parts...
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
