Fan only works on high
Old Apr 14, 2010 | 06:26 PM
ghettomaximaz's Avatar
Hello
It appears that the fan unit only works on high and not any other speed in the car. I believe this has happened before but I do not know what I did to correct it when it last happened.
Is there some fuse that needs to be changed? If not, do you know what else it could be?
Gmax
Old Apr 14, 2010 | 06:29 PM
ATTappman's Avatar
Blower motor resistor pack.
Old Apr 14, 2010 | 06:44 PM
sharzonie's Avatar
Originally Posted by ghettomaximaz
Hello
Gmax
as ATTappman said its your blower motor resistor. You can either buy a new one for around $25 or if you know how to use a soldering iron then you can fix it yourself. Im pretty sure there are a good amount of threads on how to fix/replace it....just search...
Old Apr 15, 2010 | 11:30 AM
RA021526's Avatar
There are lots of threads telling you what the problem might be, but I couldn't find anything about how to fix it other than replacing it. Here's what I did:
-pull the thing out - it's under the glove box, search for that (in the forums, I mean)
-bust out your soldering iron
-see the bumpy things on it? You have to scrape those off or use the soldering iron to fix them up. Either way, you have to heat those bump things up and remake the connection. It wouldn't hurt to add some new solder on there.
The fsm says not to do this, but my car hasn't set on fire yet.
You can check it with a ohm-meter, instead of plugging it back in after soldering.
Good luck!
Old Apr 15, 2010 | 01:41 PM
defiance's Avatar
This happened on my 87 toyota camry I just replaced it with a junkyard unit.
When the fan is on low or medium the unit gets a little hot because its taking the
extra energy from the battery and using it to heat up rather then send the energy
to the blower. Slowing it down on various setting like a dimmer switch.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
