300zx engine swap
Old Apr 18, 2010 | 05:28 PM
95maxse3000's Avatar
300zx engine swap
how hard would it be to swap the engine from a 300zx twin turbo to a 4th gen maxima. and also could your just switch the uim and exhaust manifolds form the 300 to get the twin turbo setup?
Old Apr 18, 2010 | 05:42 PM
B_Eaze's Avatar
its Rear wheel drive and won't bolt in so its gonna be your job to figure it out. Unless your r skilled like in Overhaulin's WHOLE team (which i'm guessing your not) or wanna pay $$$$$$ its not likely gonna work out... why would you wanna try that anyway
http://forums.maxima.org/all-motor/3...urbo-swap.html
http://forums.maxima.org/all-motor/2...-end-swap.html
http://forums.maxima.org/3rd-generat...00zx-swap.html
http://forums.maxima.org/3rd-generat...win-turbo.html
http://forums.maxima.org/3rd-generat...-speed-se.html
know whats weird though, all the thread I posted are locked. Why is that?????????
*sarcasm*
Old Apr 18, 2010 | 05:58 PM
*sarcasm*
its a 4th gen maxima. the engine might not bolt to the tranny but do you think that the manifolds and stuff can be swapped out. they are a 3.0 nissan engine. idk if the 300zx is z vq30de thow
4thGeN's Avatar
u can do the swap and have it rear wheel drive BUT your unibody 4th gen wasnt made for body flex like that. u would have to cage it and pound the fire wall in and new motor mounts possible wheel well work fron and rear and u would have to get a diff with a custom length drive shaft blah blah blah...better off trying to do a 350Z swap
Old Apr 18, 2010 | 06:04 PM
ok thanks.
Old Apr 18, 2010 | 06:06 PM
B_Eaze's Avatar
VG30 components are not interchangeable with VQ. The links I posted actually contain information
http://forums.maxima.org/2935777-post3.html
SPiG: "The VG and the VQ have no common internal parts. To my knowledge there is not a single part that will bolt up. The only thing that we can use is the injectors (only for 95-96 Zs) and the MAF if boosted. There are also some brake components but nothing as far as the engine. The 350Z has a lot more parts that we can use regarding the engine. The 89-94 maximas have the VE30DE and the VG30E so they have more parts in common with the Z31 and Z32.
like the other one."
Old Apr 18, 2010 | 06:08 PM
ok thanks. how hard it it to do a 3.5 swap out of a newer max?
Old Apr 18, 2010 | 06:13 PM
mtnbikeair's Avatar
There is like a million threads. Just look.
Old Apr 18, 2010 | 08:18 PM
HandsonMaxima.'s Avatar
possibly an 6 out of 10. 10 being talking sense into an angry woman.
Old Apr 18, 2010 | 08:54 PM
aackshun's Avatar
Get a 3rd gen, lol.
Old Apr 18, 2010 | 09:02 PM
dan1el's Avatar
The VG is an iron block and to my understanding the VQ30de is several hundred lbs lighter than the vg30de. You would probably come out cheaper, lighter and with less headache if you keep the vq30de and turbo it.
FWIW I've read a few people that spent the money and energy swapping either a vq30 or vq35 into a 300zx to drop weight.
Old Apr 18, 2010 | 09:15 PM
what would i have to to do twin turbo a vq30
Old Apr 18, 2010 | 09:27 PM
dan1el's Avatar
I'm not sure. There's plenty of folks on here pulling over 400HP with a single turbo. I think the vg30dett (twin turbo) stock pulls like 300. I think you can find a lot more info on turbo projects in the turbo/super section.
Also, I looked into getting a vg30dett from a salvage yard and on the average they run like 5x the price of a vq30de. So you could probably turbo the vq for just a little more money (not including labor and fab work). You can pick up a vq for like $200-$300 and a VG is easily $1200 based on what I found. So overall the vq30de turbo would probably cost way less time and $$$$.
Plus timing chain FTW. VG has a timing belt and that scares the crap out of me.
Old Apr 18, 2010 | 09:29 PM
nothing, you would single turbo it and get more power
is this really that hard to accept?
300zx=rwd maxima. end of story TT300zx=a basic turbo maxima. only 300hp
and please fix your sig its huge and its very hard to read threads you post in.
Old Apr 18, 2010 | 09:30 PM
beat me to it
Old Apr 18, 2010 | 10:14 PM
Rood's Avatar
300zx DOES NOT = rwd maxima
PLain and simple
Old Apr 19, 2010 | 01:00 AM
v3rtex7740's Avatar
PLain and simple
Even though the idea of a RWD maxima seems really fun.
Old Apr 19, 2010 | 03:38 AM
Blakfreestyle's Avatar
A rear wheel drive max would be fun. Why re-invent the wheel when the Infiniti J30 is available, so is the older q45 series. Not to mention the 300zx twin turbo is a nightmare to fix. Explains why nissan,toyota,and mitsubishi quit making the the twin turbo setups.
Old Apr 19, 2010 | 05:58 AM
ok so single turbo is the way to go. how many pounds of boost would it be safe to run.(engine was rebuilt 50k miles ago)
Old Apr 19, 2010 | 06:03 AM
ampire's Avatar
put a big turbo on one cylinder bank and a little turbo on the other cylinder bank?
Old Apr 19, 2010 | 06:04 AM
cashoit's Avatar
in before the lock yah!
derekinthez
Nov 13, 2022 04:00 PM
BkGreen97
Apr 2, 2016 05:47 AM
fastcarny
Oct 6, 2015 10:42 AM
I<3 A32's
Sep 10, 2015 11:07 AM
