Check Engine Light possibly burnt out?
My check engine light was on so long that I'm afraid it burnt out. One day it just stopped showing up at ignition.
I've searched around the forum and the sticky for changing dash bulbs in no longer a valid link.
I've also seen some post refer to checking a fuse but I don't know which one this could be.
I also saw some posts saying this could be an even more serious problem. I currently just go to Autozone and have it checked but I'd really like to see ti again!
Any tips?
Dom
Any tips?
Dom
Are you it is burnt out? Cause if the codes ever resetted or if there was some type of error there is a good chance it will just come back. The only thing i can say is put ur car on in the ingnition start but dont start the car and see if it goes on or not. That is why all the lights turn on in the cluster to test of they work or not. Also the job is pretty easy to swap out. Pmoar has a cluster removal writeup and youtube link. GL
Pmhor or. Smethinglike that. He is basically one of the insane gurus here he used to post a lot back in the day dont know were he has been. Cause he knows almost everything down to fsm and part numbers of our cars. Lol
It's pmohr and here is a link to his "how to" videos -
http://www.youtube.com/view_play_lis...E3C3345DC2C64F
because everywhere I took it just said "it's some vacuum code and it probably isn't worth fixing cause it's gonna cost you tons of money to figure it out".
the car ran fine, the light didn't blink and I just lived with it.
they bs u...i had the same issue on my car. the valve is a lil valve right behind the rear driver wheel underneath the car. My mech did the work..,turned out to be some corroded wires. Mech didnt even charge me. Grab the FSM and jsu troubleshoot urself. That code is not hard to get rid off
thanks for the inspiration! i've been gradually tackling problems from the severe, as in huge exhaust leak and no power, to the medium, stalling at red lights... now its time to fix teh little bs issues now that i have a little confidence under my belt.
i have zero electrical experience, maybe its time i learned to use a tester? is it possible its just the valve and something i can just pop off and replace?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
