95 maxima ac compressor making noise after W/p install.
Old Apr 28, 2010 | 08:39 PM
TravisCadello's Avatar
had a guy install my water pump last week and when i got it back i immediately noticed a bearing grind noise and it went away when i turned on the AC. its comming from the compresor.
what could be the problem? it never done this before he did the work. he said something bout my pulleys or bad ac compressor. we put a can of freon in the system cause it was a bit low i never put freeon in this car last 4 years so no leaks. and he said the high pressure side is low pressure maybe bad ac drier?
what could be going wrong? Thanks,
Old Apr 29, 2010 | 06:47 AM
njmaxseltd's Avatar
The bearing is on it's way out.
You need a new compressor or an attempt to put a new bearing in yours.
Old Apr 29, 2010 | 12:32 PM
How much is Labor normally on putting that bearing in? cause new compressor is EXPENSIVE.
and how long doe it last? and what happens when it goes bad?
thanks,
Old Apr 30, 2010 | 01:03 AM
anybody know? or should i just put a used one in?
Old May 1, 2010 | 08:42 AM
oldngivout's Avatar
Willing to learn
In order to install the water pump, the Alt/AC belt was removed. Quite possibly the new tension set on this belt when reinstalled by the mechanic has brought to light the pending demise of your AC compressor bearing or the belt tensioner pulley bearing. I would do a little investigation to see which one is going bad. The tensioner pulley is a cheap & easy fix. But you're right, the AC bearing not so easy.
Old May 1, 2010 | 05:50 PM
z32drifter's Avatar
Second checking the belt tensioner pulley. I got one of the washers flipped the wrong way on the tensioner when I put it back together causing a grinding noise.
Old May 2, 2010 | 04:49 PM
how could i see which ones doing it? im pretty sure its the compressor cause it goes away right when i turn the ac ON. and how long will it last till i can fix it? i dont want compressor locking up and belt coming off across town.
Old May 2, 2010 | 06:56 PM
maxfever1987's Avatar
do you have engine splash shields on you car at all? by not having those your compressor is exposed to water which will cause yuor ac compressor bearing to sieze up
Old May 2, 2010 | 09:21 PM
maybe thats the problem i dont got the splash shields and haven't last 2 years.
Old Jun 18, 2011 | 07:43 AM
juschillr1's Avatar
Sorry to wake this thread up but I'm having the same problem now. What did you do. Change the compressor or bearing and how much did you pay.
Old Jun 18, 2011 | 11:43 PM
its cheaper to just replace the compressor. I drove mine a good 6 months and 8500 or more miles with the noise but i just left ac on always. Good luck,.
Old Jun 20, 2011 | 01:50 PM
look4judy's Avatar
i had the same problem after the tech change tha wp he said it was the polli and we change it including the ac band but the noise still there (like a shaky sound ) and when we look to the polli it looks like is shaking from side to side no to hard but still se it .....is this normal? i know all the cars chake but i still have questions and no money to pay the tech? help plz!
Old Jun 22, 2011 | 08:11 PM
tighten the tensioner bolt on pulley. mine was loose and also made a noise. with the idler pulley tight tighten on the bolt that put tension on belt and it should clear that slack up.
Hondarydr
Dec 30, 2024 06:15 PM
PH98I30
19
Jun 13, 2016 02:38 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
