ROTA P45R 18x9.5 30 offset will they fit?!
Hey
Has anyone ever put a rim with this spec on a 4th gen? Does it poke out a lot? any issues?
The Rims/Tires:
ROTA P45R 18x9.5 30mm offset with Falken Azenis RT 615: 245 40 18.
Thanks!
The Rims/Tires:
Thanks!
If your lowered you will have to roll the fenders for sure, and if you want the tires to sit flush and tucked they will have to be streched.
NismoVQdet? is running these wheels, and this same size I believe. Hit him up
Here is his ride...
Same wheels, but with stretched 225's
The P45's are awesome wheels with their concaved look, but in order to acheive that they have to have the low offset and I dont like the poking out wheel look.
Nor do I like the streched tire look with the exposed lips from the rims.
However, BMWs have different bolt patterns then Maxima's and they will not fit in that aspect.
How much rubbing will it be while turning? or will they not rub? I would like to know cuz im thinking of doing the same thing. THe stretched with the same exact wheels but i dont wanna go through tires like crazy.
Just a small update. I got the Rims and tires a while back. There is no rubbing at all. Perfect fitment. Only thing is the front tires poke out a little, but I like the look. Will post pics later.
if you are not dropped or on a 1" drop, its not going to rub but that was the obvious part.... go down to 2" and u will see those tires shred........ 1" is not even a drop in my book.
I like the P45s but I don't like the poking out in the front nor do I like the stretched tires and exposed edges of the lips.
no rubbing at all until you hit a dip.. wheels turned full dont rub and im dropped 2.2 when i buy new tires i wanna do 245/40/18 +30 is cool in the back but you really need +35 in the front so they dont stick out and you dont have to have some crazy streched tires..
Yeah I would go w/35's in the front, doesn't look right, plus when you hit bumps/dips like you said.
I love the way your wheels look, that concaved face is killer but I just dont like the front wheel poke.
Thanks for posting this pic. It reassures me that I didnt go with too short a tire. I special ordered some 18x8 +40 ASA JH9's and 225/40 Conti ExtremeContact DW's (not to be confused with DWS). Actually at first I ordered 235's but went back the next day to order 225's instead. Dropped on Boss Chens approx 2.5 all around. Im sure clearance wont be an issue but I believe Im off by a bit to being flush. So for the question that I'm sure has been discussed for the umpteenth time (my bad for that), would a 10mm spacer (rear) and a 5mm spacer (front) get me flush?
Sorry for hijacking the thread.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
Good ta see ya around
